Turning end grain?
Cleveland, Tennessee
Is there a rule of thumb for turning end grain? Have a piece of, I believe, cherry mounted on the lathe. Piece is 3-3/8 in diameter and 4-1/4 long. Started to hollow with a Forstner bit but wasn't comfortable with the "action" of the Jacobs chuck in the tailstock. Any and all suggestions are welcome.
Well, there are many methods, but most turners including myself, hollow from the center out, using a spindle gouge or a Hunter hollowing tool. For your size piece of wood, these tools should be no problem.
I don't prefer a forstner bit because of the heat produced and the way it leaves a straight hole with a divet in the bottom.
Also negative rake scrapers are a great choice, such as these from D-Way. If you are going to hollow a lot, these tools are an excellent investment and leave a very smooth surface. They also are excellent for blending the interior curve.
