Turning small projects with green wood
Waunakee, WI
I'm still learning on my lathe and have been doing a lot of smaller projects, such as bottle opener handles and snowman or christmas trees. I recently picked up some maple logs between 2 and 5 inches in diameter. I turned one of them into a snowman and it turned well, but was hard to sand since it was still wet. I've been trying to research how to dry logs for small projects like this but can't find much information, everything seems to talk about drying wood for bowls. What is the best way to use this type of green wood? Do I need to remove the pith or can I turn them as is? Should I just leave the logs alone for a while, or should I turn them to get the bark off and then let them sit to dry?
2" in diameter is a branch, definitely not a log. Every whole branch will crack. Drying wood, small or large, dries with the same rules. It shrinks more around the outside than the center, so the cracking starts on the outside. A better type of green wood to use is split firewood.
I first was introduced to green wood turning in 1989 with Dell Stubs who demoed a thin walled goblet in cherry and have been doing it ever since. Dell did some tapes on the subject but I don't know that they are available on a modern format.
The above were done in 2019 from a small black cherry about 3" in diameter. To be successful you must use fresh cut live wood and turn thin in both the cup and the base. The pith is generally not in the center so therefore the stem will be stronger.
The end grain goblets gave me the idea to try hollow forms with the pith included so this juniper lidded urn has the pith in the base and of course the top opening eliminates the pith on top. These are usually rough turned, dried and finish turned. The full round presents the wood grain in a way I think is very attractive and not attainable any other way.
This ash box is my latest idea, where I use straight grain featureless small trees, this one was about 5 1/2" in diameter turned to a uniform 1/4" wall, a 4- 3/8" diameter opening on top and a 3" diameter base. The lack of knots or swirly grain meant that when dry the opening was still almost a perfect circle.
I have to disagree with you it can be done it just takes a little practice.
I have dried some small 3-4” diameter holly limbs and saplings. I left them in 3 ft lengths sealed the ends with ancho seal and let them dry for a year. About a 1/3 split. Wood shrink more tangentially than radially. Basically each growth ring wants to shrink more than the wood inside. So the wood cracks to relieve the stress. In small diameters they don’t always crack.
There are some other items you can turn from green wood to build your skills.
Natural edge bowls, Goblets, small vases, napkin rings can be turned from green wood
Abranet sand wet wood nicely.
These are all require skills at the advanced basic or intermediate level.
I’ve done napkin ring workshops with beginners.
See this thread
Napkin rings can be turned from green wood. This process drill out the center
three center turned Napkin Rings -
View: https://www.youtube.com/watch?v=Ys4tMzwh7jE
Todd, as others mentioned so far, there are lots of ways to use green wood and I’ve done many.
However, I far prefer to turn dry wood. As for drying wood for small or larger projects, it can be VERY difficult to successfully dry log sections. Due to the nature and structure of wood, primarily the way it shrinks at different rates for tangentially to the rings vs radially, a log section will almost always crack. This depends on many factors including how it is sealed and stored, the temperature, the relative humidity, and the species of wood. (Some wood like mesquite and sassafras are far more stable than others like fruit woods, oak, dogwood, etc.)
Water in the wood escapes the log section far more easily through the end grain so the end of the log will start to dry and shrink quicker and check and cracks can form, sometimes quickly. (Cut some round sections and they can start to check within a few minutes.) These initial cracks will soon turn into large cracks and splits, quickly turning the log into firewood, The best thing to do with green wood, regardless of what
One defense, as show here and by “twice turning” bowls, is to turn a thin or relatively thin wall which can dry without cracks, depending - the thinner, the better, or with proper drying for thicker walls.
However, for my uses, I cut the logs up into square or rectangular sections and dry those. Some sizes and species may take years to dry while some may dry in weeks or months.
But when some one says they are still learning on the lathe, really thin walls are usually out of reach.
Quite true - They have trouble with thick walls too.
I’ve taught kids 8-80 they can all do it with classes. Few make it quickly teaching themselves
In my greenwood demos I point out the habits of successful greenwood turners. Newbees rarely accomplish them with any measure of consistency. With a good class they are well on their way
Link to greenwood
Let them dry before sanding. There are myriad ways to dry. I would consider drilling a hole through your snowman to facilitate drying with less cracking.
Drying methods:
  • Microwave: Microwave on defrost for 1:30-2:00 minutes at a time. Let cool for an hour or so. Weigh the piece. Rinse and repeat until it stops losing weight. This is a fast drying method, and might lead to cracks in some woods.
  • Paper Bag Method: Put the piece in a paper bag. Change the bag every few days. Some people add shavings to the bag, but I understand it works just as well without the shavings and with less chance of mold. This is probably the slowest and safest drying method.
  • Just let it sit. I do this a lot. If the wood is stable and isn't going to crack, I just leave it in the house for 4-5 days, weighing it every day until it stops losing weight.
  • Others: Dessccants, boling, etc.
Todd, I've been drying my smaller blanks (3x3, 4x4 etc) in desiccant. I take the small chucks left over from cutting bowl blanks and box blanks from wet wood and throw them into a big Ziplock for about a week, then I let them sit for a week to equalize. I've had good luck thus far. I bought an 8lb jug of color indicating desiccant off Amazon for about $36 and when the color changes you can dry the desiccant out in your oven (I've been using a solar kiln for that but that another topic altogether). Might be worth trying to green turn, dry in desiccant then sand. For $36 and a tree limb the experimental possibilities are vast.
I buy quantities of indicator desiccant for various shop uses and dry them as needed with the shop toaster oven in small aluminum containers. A couple of things: the stuff works well in a airtight container to greatly increase the life of CA glue (water vapor is an accelerator and the plastic of most CA glue bottles lets water vapor through.) Also, if you can find non-indicator (usually white) desiccant cheaper, just add a small amount of indicator desiccant and shake to mix. Even a few indicator beads in the lot will let you see when they all need to be dried with heat.
I have turned hundreds of Birdhouses, and basically all, or most were turned from green wood.
Thin-walled and they never split that way, here are a bunch to be delivered to an art store that sold them for me.
I stopped with doing so many, as it became a job, demand was there, but I turn for the fun of it, still turn the odd one, as some wood just wants to be used for things like that.
I made a pencil holder for my mom when i was about 9 years old out of a piece of a black acacia of some sort, was a branch about 2-1/2” around, just sanded and sanded and sanded and drilled some holes in it to hold pencils,
She still has it on a desk in her room at 93 years old, not a crack in sight, so no, they dont always do anything
A couple of techniques you might experiment with, either before or after the small project (e.g., bottle, stopper) is turned: (a) boil the wood for an hour and leave it in the water while everything comes to room temperature - if you do this with the stock before turning, let it dry before turning; (b) soak the wood in denatured alcohol for 24-48 hours, remove and leave in a paper bag for a day or two - this might be the fastest, as even if you use it on unturned stock (small piece) the DNA should evaporate fairly quickly. It has replaced the water in the cells. I use this technique on once-turned bowls, especially fruit woods.
Jamie, am curious, can the alcohol be re used? Say if i stick it in a big plastic container like a 5 gallon bucket? Easy enough to find a big vat to boil in but would be great if the alcohol can be used more than once, assume it can but having never done this want to check
Well, correct me if I am wrong here, but I think the alcohol will do the same thing as the LDD (liquid dish washing detergent, 50/50 mix), it will pull a bit of the color out of the wood, probably the boiling will too. This would mean a separate bath for black walnut than you would use for any of the maples. The LDD soak does heighten the red tones of the madrone, and that purple/red can look good on the myrtle I turn.
Yes, it can be reused for quite a long time. The alcohol will change color (e..g., red after Madrona) but that color doesn't seem to affect the next blond piece. Only downside I've heard is that on some woods it may cause a little color bleeding (within the piece).
Cool,
This i think i will try, been turning small bowls etc to work on my technique, all from green branches and oddball chunks from the wood pile, easy enough to drop something in a five gallon bucket then fish it out after a bit then pop a lid on the bucket for next time, like the idea of dunking a chunk of un turned wood in there, have a ton of small pieces just calling my name, kinda scary actually, ahem but thats another issue 😎🤙🏻
