Here is an idea based in science, not opinion.
The next time any of us have a big chunk of wood, or several smaller of the same species, before you make a single cut, sharpen the tool you intend to cut with. Gouge, skew... doesn't matter. Then just before hitting the on button of the lathe, set a countdown timer on your phone. Or on an oven timer. Whatever. Set it for, oh, let's try 10 minutes. Ready, get set, GO! Turn continuously for 10 minutes. Don't stop. Same cut, over and over. Good cuts, bad cuts, just cut. 10 minutes goes by fast. And... ding-ding! Stop the lathe, go to the grinder, whether you think/know you need to or not, and sharpen the tool again exactly the same as last time. Reset the timer, and GO! 10 minutes later, re-sharpen. Repeat 3 or 4 or 5 times, the same way. Are you noticing anything about the cut quality after sharpening? Slight improvement? Major improvement. Do it again, and again, and again. Thompson tool, cheap crap tool, doesn't matter. Repeat, repeat, repeat.
Conclusions:
-10 minutes might be totally unnecessary for a high-end steel tool. (Experiment at 15 or 20 minute intervals as described above.)
-10 minutes of turning really does (maybe?) dull down a steel of a different alloy than M42 or other high alloy powder metals, and you just proved to yourself that frequent sharpening is a good thing.
- We ALL need to get over this idea that stepping over to the grinder, regardless of the steel, is somehow the negative part of woodturning. It is not. It IS PART of woodturning. Like other areas of life, it's not the tool, it's what you are able to do with it. So, chasing the next great tool, dropping $200 on it, all so you can save an accumulated... 10 minutes of time in a 4-6 hour turning session... so what! $75 for this tool, $200 for the same exotic metal tool... that's a lot of pizza money! An M2 gouge, a Varigrind jig, 3-4 quick swipes across a wheel inside of 30 seconds of time, and it's surgically sharp again. Get over it.
-Either way, we all have/had to learn in our early turning life to "listen" to what the wood and the tool and our hands and our senses are trying to tell our conscious minds. "I'm pushing hard. The wood is tearing. Where did the ribbons go? Oh, maybe I should resharpen, it's been... 30 minutes since the last sharpening?!"
Sorry
@Bill Alston for being a highjacker of your thread. It's fun to experiment with new things like this. It's just how Mike Hunter did it with his tools 20-some years ago. If at first you don't succeed...
