Lou, glue your wood up right after milling; it should stay stuck. If you wait, give it a wipe with Acetone and it should glue fine.
I’ll make a few test joints with CA and Titebond and see how they stand up before doing anything too dependent on glue joints… though I realize it won’t be a long-term test.I don't know that I would ever trust a glue up. I would expect that over time, the oil from the wood would loosen the bond.
That's not rosewood, at least not Brazilian. You would know because it smells very sweet and floral-like roses. LOLThanks for these suggestions Al. Very neat little seed jars!
John, I imagine it is Brazilian. I’ll try to key it out when I can find a key that includes exotics. I have now had a chance to cut off a few pen blank sized pieces. This from one of the plainer pieces, but some of them have more black or darker streaks running through them.
https://images.app.goo.gl/khM6w4DL4m5gWCiz5 I found this picture of interest, at least I think it is. I have better luck distinguishing wood by end grain, absolutely no expert on any domestics, let alone imported.Richard, John and Tom, alas, I’m sure you’re right. It is in fact a stained or dyed surface color and even striping. I’m planning on sending a sample to the Forest Products Lab in Wisconsin to see what it is. At this point, I’m just curious. Here’s a closeup of the end grain.
My first bowl made at age 13 was a cherry and rosewood glue up. My folks used it for 45 years and its ownership reverted to me 2 years ago. We still use it, and getting it back got me back into turning after a 50 year hiatus. It shows no sign of weakening.Fret boards for guitars if they are long enough, banjo, mandolin, ukulele......
I don't know that I would ever trust a glue up. I would expect that over time, the oil from the wood would loosen the bond. Maybe not, but I have never tried....
Richard, I assume you’re basing this on the idea that it is in fact rosewood. I’m waiting to hear from the Forest Products Lab, but am pretty much resigned to the idea that I’ve got Jatoba or something similar. While this is very hard wood, I don’t know if it is generally used in that manner.The larger pieces could go for guiter/mandolin fretboards.
I just received my response from the US Forest Service Wood Products Lab. They report that the specimen I sent is Anadenanthera sp.
Here’s the wood database write up of it: https://www.wood-database.com/curupay/
Apparently one of the common names of this is curupay, also known as Patagonian rosewood. Too bad I didn’t get any of the foliage or bark with it, as it is an hallucinogenic, used by shamans! So, yes, a rosewood, but only by common name - not Brazilian rosewood. In any case, it is attractive and very heavy. I’m looking forward to finding uses for it.
