  • Sign up for the 2025 AAW Forum Holiday Swap by Monday, November 24th (click here for details)
  • Congratulations to Tracey Lee for "Huggins with Rope" being selected as Turning of the Week for November 10, 2025 (click here for details)
Using 3/4 bowl gouge - 5/8 flute - on a 1HP lathe?
I'm looking at purchasing a Crown Tools 243PM 3/4 Inch PM Bowl Gouge. I have a Jet 1221 1-horsepower lathe. Will this gouge be too strong for turning green live-edge bowls?
Might depend on the sharpness, your skill, the speed/related torque, and how deep the cut is. Removing large amounts of wood at once with that gouge might be challenging.
I've used a gouge similar to that on dry wood on a 1hp lathe. Wet wood is easier. But why so big a gouge? Seems a 1/2" or even a 3/8" bowl gouge would work fine and may be more appropriate. But I don't usually turn green.
But maybe you know someone who would loan such a gouge for you to try before you buy.
With a light cut (relative to its cutting capacity), you'll be okay. Take a heavy cut and you may overwhelm the motor. Set the pulleys to let the motor run fast for the spindle speed you want, that will help.
1/2" and 3/8" gouges will be kind to the motor and reduce a lump of wood to shavings quite quickly on a 12" lathe.
I agree with @John K Jordan and @Sam Force. I have one (Henry Taylor I believe) and I have rarely used it. That being said, I don't recall any problems using it on with my 1 hp lathe - but I probably wasn't using it to take extra heavy cuts either ... hence, my preference for a smaller gouge.
Thank you for the reply!!!!! Such a great organization to be a member of.
I've seen these used on larger/stronger lathes, and they worked wonderfully.
Wish I knew someone close by who turns to try (the nearest club, 90 mins one way), will have to go easy now on the 12-21, but I will have a use for it when I upgrade. (Cheaper now than later).
Well, it will never be as affordable as it is today. Get it, and dream of those giant shavings yet to come. Fresh from the wheel, those Crown Pro PM tools can be wicked sharp, and very willing and able to strip the hide off any lump of wood.
After reading many of the above opinions, I am reminded of a lighter I used to have that said "It isn't the size of the rod that matters, it's how you wiggle the worm") - technique and sharpness trump gouge size any day of the week. I can't imagine using a 3/4" gouge - I use a 5/8 sometimes but usually just for roughing , and I run a Jet 1642 lathe. Only reason you'd possibly want such a big gouge is when quickly roughing out a bowl to round - but if you're already round, you'll probably find a 3/4" gouge just entirely too big for finer and detailing work especially on a 12" or smaller bowl... I'd call it a waste of money, myself...
A production turner friend used a 1/2" bowl gouge for all of his work -- bowls up to 12-14". I have a 5/8" bowl gouge which I rarely if ever use. I find a 1/2" is plenty.
I have a 3 hp lathe. I was given a 3/4" gouge. I gave it away. Too heavy. I can take huge cuts with my 5/8". Just didnt see any benefit of that tool.
