Two things you need, CFM to overcome leaks, and a good enough pump to reach a low vacuum level. Most woodturners will be more than happy with a pump in the 3-4 CFM range, and you'll want to be be able to get at least in the 20 in. Hg range, if not more. Actual vacuum you can get will vary on the ambient air pressure, also effected by elevation. If you're in a Denver, you'll pull less vacuum than in San Diego. Another thing people ignore is the size of the chuck. Larger chucks have larger surface area, and that's more area for the vacuum to work with.
