• It's time to cast your vote in the November 2025 Turning Challenge. (click here for details)
  • Congratulations to Konstantin Gusev for "The Nutcracker" being selected as Turning of the Week for November 17, 2025 (click here for details)
Vacuum Pump converted for Airbrush
Arlington, VA
I'm trying to make my vacuum pump into a compressor for a new airbrush but running into complications. Is it a fools errand?
I've run a hose from the outlet (pressure) of the vacuum pump into a regulator and then to the airbrush. The problem I'm running into is that the vacuum pump runs continuously and there's no relief for the pressure that builds up between the pump and the newly added regulator. I would imagine that a cut-off switch installed to turn off the vacuum pump when the outlet pressure builds up, or install a relief valve that I'd manually adjust. Or perhaps some of you have a set-up that works differently.
Thanks for your ideas.
What we use for vacuum pumps are often used as small low-pressure compressors. For instance, they are used for aerating a pond. Depending on the pump, running continuously when no air is moving may be perfectly OK. Check it to see if the pump is getting excessively hot. If you're running cool or even warm, you probably don't have a problem. If it's getting hot, you may need a Plan B. I think if you're using one of the vacuum pumps that uses oil, like those used in refrigeration, you may get extra oil mist doing what you're doing.
I run my airbrush off the shop's air compressor (with a regulator in-line with the airbrush).
You need to keep the pressure into your regulator above the regulator's setting - otherwise you'll have pressure fluctuations at the air brush. So either let the pump run continuously or else have a tank and cut-off switch between the pump and regulator. The tank will smooth out the pressure when the switch cuts off.
If you go the tank route.... By the time you find something for a tank (old propane bottle, freon tank, something else similarly sketchy - or else obtain an actual portable storage tank), add the pressure cutoff switch, plus whatever valves and fittings needed... you might as well buy a small inexpensive pancake compressor. If noise is an issue, you can run it to charge the tank outside and bring it in for the job. The air in its tank will probably last a good long time for just an airbrush.
This is my setup. I do have an off on toggle valve. Basically a switching valve with A and B outlet. I plugged the A outlet that shuts of the air. The needle valve is for my dentist drill setup and not needed for an airbrush. I can run off my vacuum pump pressure side or my air compressor. I have a Thomas vacuum pump (oilless) and it can run 24/7 continuously. However I always use my air compressor.
HD means I got it from Home Depot and HF is from Harbor Freight.
Cheapest route is to put a bleed valve in line so you can dump excess pressure and also carry away the excess heat. If you have a pressure gauge on the line it should be easy to set the pressure to a bit above the regulator setting. A spring loaded overpressure valve would be even better as it would close if the pressure drops beyond a set point.
Thanks for all the advice, and for offering it so quickly! I'm just "dabbling" in airbrushing, so for now, I think that I'll just use the shop air compressor. I like @Gary-Beasley's suggestions to add a bleed valve in-line, and I might re-visit that later.
I have a tiny Badger airbrush compressor and it runs constantly , that’s how many of them are designed. Especially the cheap ones. I just have a cheap remote control /plug that I use to turn it on and off.
These types of compressors have no tank or regulator, they just run and run and run.
All my airbrush compressors have small tanks on them and are on demand.
I have airbrush compressors like that too.
I was merely pointing out that the entry level ones for airbrush manuf. don’t have tanks or regulators, run constantly and work just fine. Hoping that info might help out Ken in his quest.
Make sure you have some type of moisture trap when using an air compressor. Harbor freight used to sell a cheap regulator that had one built in. You can find them for under $20 on amazon now. I like the self draining ones that have a spring loaded drain in the bottom that automatically open when the line depressurizes.
