Like others, I use a fuel filter from Napa. Cheap and clear so you can see when to replace it. So far I haven't needed to.I'm helping a fellow woodturner set up a new vacuum system. I have sourced most of the valves and piping and gauge but I'm at a loss for what to use as an air filter on the pump. It's a nice Gast pump
Replace it? What a novel idea, lol!!Like others, I use a fuel filter from Napa. Cheap and clear so you can see when to replace it. So far I haven't needed to.
With good results, I've used cheap auto air filters, but they're a minor hassle to replace, as you have to get the filter unit unplugged from the tubing, maybe losing an inch of tubing each time. The unit suggested by John is a wee bit more expensive, but allows you to unscrew just the housing to clean or change the filter without taking the unit out of the tubing. I like it. If the filter is steel mesh, as implied, rather than paper, it could be cleaned a few times without replacing, which would make it cheaper than auto filters!Joe Woodworker, Veneer Supplies and vacuum pump expert,
(https://www.veneersupplies.com/) recommends this one:
High-Flow Vacuum Pump Filter with 1/4" NPT: $16.90
This vacuum filter is perfect for the vacuum press systems we offer and can handle up to 10 CFM of vacuum flow. Each filter comes with a micro-mesh particle filter made of stainless steel.www.veneersupplies.com
Didn't realize cost was an issue with the tubing. Think it was around 35 cents a foot at ace hardware when I put my system together 3-4 years ago.With good results, I've used cheap auto air filters, but they're a minor hassle to replace, as you have to get the filter unit unplugged from the tubing, maybe losing an inch of tubing each time. The unit suggested by John is a wee bit more expensive, but allows you to unscrew just the housing to clean or change the filter without taking the unit out of the tubing. I like it. If the filter is steel mesh, as implied, rather than paper, it could be cleaned a few times without replacing, which would make it cheaper than auto filters!
