Vacuum Pump
Montgomery, TX
www.gulfcoastwoodturners.org
I want to begin working with a vacuum chuck. The Surplus Center used to have a pretty decent vacuum pump (Gast 0523, Surplus Center item no. 4-1540) at a very good price - $89.95. It is no longer available.
Does anyone have new Gast 0523 vacuum pump from The Surplus Center that they want to sell?
Does anyone have a source for new direct drive, oil-less, rotary vane vacuum pumps that are lower priced than the usual woodturning mail order houses? - John
Try Bernie McGivern:
http://www.hydraulicpartsnow.com/
He is a woodturner and member of our Club. He used to have some not brand new (but looks brand new) vacuum pumps to sell to our Club members at very good price.
He has organized several CA glue and band saw blade group buys for our Club members.
I don't know if your area has many pawn shops, but mine does. I was able to get a pump for $30.00. I t works just fine.
Aaron
I got an outstanding one for about $25 on ebay -- a company that makes orthodontics was selling some of their used ones and replacing them with newer bigger ones. Shop the industrial section of ebay. It is a good way to buy stuff as long as you are confident in your ability to evaluate sellers and are able to discern between junk and good stuff. Deal only with sellers that have near perfect ratings.
I use the one you noted is no longer available. However, on the Surplus Center's website you can get a very, very similar Gast for $35 less.
http://www.surpluscenter.com/item.asp?UID=2008100118301052&item=4-1669&catname=air
If I were in the market again, I'd go with this one.
I just finished building my vacuum pump cart with the vacuum pump Owen mentioned. I bought it at Surplus Center for $54.95 and it works great. The pump is supposed to be rated at 20 in Hg of vacuum but I am at 5000 feet elevation and can get about 23 in Hg with my setup.
Tom
More Is Better
Remember Folks, as you shop for a vacuum pump, CFM flow is more important for turners than inches of mercury.
When you vacuum chuck a piece, you're using atmospheric pressure to hold your piece, but that piece is wood, and will, to greater or lesser degrees, be porous and will leak air into the system. You need a pump with enough flow to both maintain the partial vacuum and make up for the leaks. Therefore, a vacuum pump that may be great for a veneering system at 2 cfm pulling 28" Hg. will be quite unsuitable for turning wood, but a pump moving 6 CFM while only reaching 15" Hg. may be just fine.
To further illustrate, remember that the larger the diameter of the chuck, the less "vacuum" you need to hold the piece. An 8" chuck has the ability to develop more than 3,000 lbs. of pressure on your workpiece at full (30") vacuum at sea level. Thus you won't need more than 10" Hg. from your system to hold that piece in the chuck with 1,000 lbs. of pressure. However, since that 8" chuck depends upon a good seal around the 25" circumference in contact with the wood that can slightly bend and wiggle during cuts, the more flow your pump will tolerate, the stronger and safer a fixing you will have. That calls for more CFM. Indeed, the original "vacuum chuck" lathe rigs used shop vacs pulling 30-40 CFM but only developing 5-6" hg.
As mentioned, there are 4 CFM vacuum pumps available at reasonable prices. I would submit that you go no lower than 4 CFM, with 5, 6 and above being preferable for a turner's application. I use a pair of 2.5 cfm AC compressors in my rig. They are reasonably tolerant of leaks, but I watch my vacuum gauge for fluctuations.
Some day I'll get a "real" vacuum pump in the 6 cfm./ 25" Hg. class.
