  • Congratulations to Jaramiah Severns for "Stacked Forms II" being selected as Turning of the Week for August 4, 2025 (click here for details)
VacuuMaster Adapter
Aurora, Ont, CA
www.revolvingarts.ca
This is a bit exotic, but in my case possibly the only solution for me to use a vacuum chuck
And not cheap.
I have an old lathe, with no through hole.
Nor can I get the spindle drilled out. The thrust bearing is at the far end.
Has anyone tried this product?
http://sierramold.com/index.php/woodturning-tools/vacuumaster-vaccum-chuck-assembly/
It looks like a Oneway style chuck adapter (and they have my size!)
Thanks
Olaf - there’s also a rotating union made by Vicmark that can be setup either on the spindle or held in a four-jaw chuck. Don’t know how it would compare price wise, but it does work well from what I’ve heard...look at vacuum chucks on their website.
A quick check on woodworkers emporium site - thevicmark option looks to be substantially less expensive...
Definitely expensive from the looks of it. I have seen them work but never used one. That being said there are a million ways to turn the bottom without needing a vacuum chuck. Now granted I have a vacuum chuck and love it but after I moved I didn't have access to it for about 6 months and still turned everything I usually turn. I just used one of the other methods of holding the work. Here is a link to an article I wrote a long time ago but it's still valid.
http://nebula.wsimg.com/7bf500f3fd5...EC0DC707F1FE36FCB&disposition=0&alloworigin=1
Also there are a ton of excellent articles and links on our club website. Look them up. http://www.cumberlandwoodturners.com/tips--links-and-projects.html
Hi John,
Yeah its about $400 - a lot more than I'd prefer to spend.
I've tried:
- Longworth chuck. Good, but only for very light cuts. and of course it needs to be a smooth bowl
- Big Adjustable jaws - I have the Oneway version, pretty good. Its totally replaced the Longworth, but with slightly better holding power and the same restrictions.
(I do a lot of odd shaped pieces that do not have flat tops)
- Jam chuck. That's my go to. My main issue here is odd shaped & Unbalanced pieces, many are large.
But you raise a good point. Maybe just keep trying to be creative about the mounting solutions.
A simple mod to a doughnut chuck is to add a stand-off of PVC pipe with foam.
This accommodates Natural Edge bowls nicely
I prefer to jamb chuck my bowls over a a resessed wood mounted in a chuck.
With a dense foam pad.
I have a vacuum system but for me the jamb chuck is simple quick and I don’t have risk of cracking a bowl from too much vacuum.
Olaf - woodworker’s emporium is in Nevada - better shipping rates than directly from vicmark, and good support from what I’ve heard.
Thanks - will check.
Unfortunately, getting stuff over the US / CA border can be really expensive.
The problem is customs and how couriers handle that. It can be good or absolutely outrageous.
Normally, I can get items shipped cheaper from China, than from the US.
Haven't tried NZ yet. :)
So much for free trade......
