Anybody on this forum have any insights or recommendations on the VB 36 Bowl Master lathe as compared to OneWay and Robust... Mainly with regard to quality durability and functionality...
...... The Robust AB is real nice machine too. For huge work it is lighter than the ONEWAY but almost as stable.
I think the motor on the head stock adds enough to stability to close the weight gap unless you going really big
The ONEWAY 2436 with the outboard table and you have close to a 1,000 pound machine.....
I did some checking on mu Robust American Beauty and with the tilt away and outboard tool rest and it is somewhere over 900 pounds. If I set the steady rest on the lathe, that brings it right up to 1,000 pounds. I'm planning to add the 16 inch bed extension which is around another 40 pounds or so. As for stability, I could be biased, but I think that the "settling feature makes it at least as, if not more stable than the Oneway. Since there is no such thing as a perfectly flat concrete shop floor, ordinarily the weight distribution on the legs would not be quite equal with most lathes until a lot of time is spent with tweaking leveling screws. A feature of the Robust is "settling" the legs to the floor and then tightening the bolts that join the legs to the main body. This is in addition to the legs being able to telescope up and down several inches to accommodate the turners preference for spindle height. The Oneway and Robust both have this feature. I don't know of any others that have adjustable height adjustment. Some people bolt their lathes to the floor and others sit it on rubber pads. Personally, I don't see any difference. However, the VB36 has to be bolted to the floor because of its small footprint without the accessory tubular bedway.
Is there by chance a VB36 users group within AAW?
I really do appreciate the helpful input from all those responding to this thread. Thank you
There is a user's group on Yahoo and a facebook page for user's as well. Don't have links handy, but searching Yahoo Groups should get you there and Facebook is pretty easy to navigate with a search.Is there by chance a VB36 users group within AAW?
