Hey, I have followed the VFD replacement instructions posted here using the Lapond VFD on a 3520b that is 8yrs old. Everything seems to be working but there are a few issues I can't get sorted. When the dial on the lathe, potentiometer is turned all the way down lathe should be off but it spins at 16-18 rpm, both forward and reverse. Seems this might be programming issue or maybe potentiometer is bad. No idea why doing this.
Also set max speed to 3440rpm as per the directions but can only achieve 2800 rpm.
Any help greatly appreciated!
Thank you
Leo
Thank you
Leo
