I've been having some trouble using Waterlox to finish bowls. Can I get some advice?
The problem is that as the finish is drying, some comes out of the pores of the wood and leaves small dots of finish on the surface. Here's what it looks like, first coat on a willow bowl:
My procedure was:
1. Sand bowl to 320 grit.
2. Apply two liberal coats of 1 lb cut of super blonde shellac.
3. Re-sand to 400 grit to remove raised grain and any excess shellac.
4. Apply liberal coat of Waterlox inside and outside. Surface was saturated, no dry spots.
5. Wipe off Waterlox to almost completely dry surface using paper towels.
6. Come back 10 minutes later, see lots of dots on surface and wipe them off.
7. Come back 45 minutes later, see lots more dots on the surface, now partially cured. Scrub them off frantically using paper towel dampened with fresh Waterlox finish.
8. Return home from frisbee golfing to see the surface covered with dots of cured finish as shown in picture above.
I'm used to seeing finish bleed out of pores of ring porous woods like oak. But I was surprised to see such an issue with willow.
So, for those of you who use Waterlox successfully, how do you deal with finish bleeding to the surface? Or if it's not an issue for you, what am I doing differently than you that might account for my problem?
Thanks,
Dave
My procedure was:
Thanks,
Dave
