If you use these inline skate wheels regularly on your lathe devices, I've found they usually last around 5-7 years. At this point there is no noticeable felt play, but they will make a high frequency squealing sound at certain rpm's that indicate some small amount of play does exist.....and, should be replaced. There are two bearings per wheel, with a bearing spacer between the two.
I'm now on my 3rd set of wheels and bearings for my Oneway bowl steady. New wheels w/bearings from Oneway are $12 ea plus shipping.
The bearing/axle spacer may be proprietary, as these 608z bearings are sized for metric axles......and what is required is 1/4" axle (standard imperial bolt size) No problem, as I have six of these from previous purchases from Oneway.....they don't spin, and have minimum of wear, so they are reusable.
By cutting down a standard bolt with a 5/16" neck shaft, an easy tool is made for removing the old bearings and spacers.
On eBay, I purchased 4 new wheels without bearings, and a set of 20 new bearings for $25 total, shipping included. Hopefully, I should be set for life now!
20 QTY 608-ZZ Ball Bearing 8x22x7 Dual Shielded Metal Chrome Skateboard 608Z New | eBay
608ZZ (8x22x7) is a single-row bearing that supports radial loads, made with Chromium Steel providing superior quality and durability. Model: 608 ZZ. Suitable to use in skateboards, longboards, inline skate, scooter, fidget spinner, motor application and industrial machinery.
www.ebay.com
Roller Hockey Wheels Indoor 76mm 78A Soft Inline Skate Clear/Blue 4 Pack | eBay
These wheels are perfect for indoor skating, and utilize the standard size 608 bearing hub. Do you need bearings, spacers, oil, or a hop up kit?. HARDNESS 78A. COLOR Clear/Blue.
www.ebay.com
