willow
This is a willow I completed February 2018. It was a massive tree growing at the edge of a stock tank north of Dallas - the log I put on the lathe was a cut-off from the lower trunk a few inches from the ground. Finished diameter is a bit over 20".
Most trees yield logs with hidden treasures (curl, quilt, feather, bark-inclusions) - I've found the best material close-to or even slightly under the ground. The piece below would be less interesting if the bark-inclusions were cut out. In fact, considerable effort was required to keep the log positioned so that the bark inclusions were prominent.
I was in a little gallery show in 2018 with several other pieces - the normal routine is to put pricing on a little card on the pedestal next to each piece. The buyers of the piece shared with me what attracted them - they had visited the Vatican and, like most, were mesmerized by the Sistine Chapel - with the two bark inclusions seemingly "reaching out to each other", they named the piece Sistine Chapel.
Maybe every log is like a box of chocolates: You never know what you're going to get.
