I’ve always sharpened a skew free handed. The attachment looks like it would reduce grinding wear due to repeatable presentation of the skew to the wheel.  It’s not expensive at $50 but is it worth it?
While I've seen many good turners use large skews exclusively, I still feel more comfortable using my 1/2" skew for smaller details/beads, etc.
You not being a smarty. When I say freehand, I mean I don’t use a jig. I do use the grinder’s platform. Maybe not the correct definition but I hope we are on the same page.Not trying to be a smart alec, but how are you trying to sharpen today? I use a wolverine platform set to the desired angle using a Batty angle tool. Sharpening the straight skew across the wheel is an easier process than turning with the skew. There should be no issue with getting a consistent grind by hand with a skew. Jigs are wonderful things, but sometimes the best solution is a quick lesson and a bit of practice.
Greg, doesn't a cloth wheel like that round over the edge of your skew (microscopically)? That type of wheel is usually used to buff/shine metals - sort of like the Beall buffing wheels for wood finishes. Wouldn't a leather, hard felt or even a large MDF wheel work better?I use oneway platform and then stropping with buffing wheel for a scary sharp mirror edge.
I have never used the oneway jig for the skew.
I've used soft, flexible wheels in the past.Greg, doesn't a cloth wheel like that round over the edge of your skew (microscopically)? That type of wheel is usually used to buff/shine metals - sort of like the Beall buffing wheels for wood finishes. Wouldn't a leather, hard felt or even a large MDF wheel work better?
Sorry forgot to add : I use both-- original stropping is done on the Tormek T8 leather wheel and then touched up on the firm cloth wheel with the green metal polish , gets things razor sharp.Greg, doesn't a cloth wheel like that round over the edge of your skew (microscopically)? That type of wheel is usually used to buff/shine metals - sort of like the Beall buffing wheels for wood finishes. Wouldn't a leather, hard felt or even a large MDF wheel work better?
