Wood Press, how to make?
Manchester, CT
Recently, in the last few months, I saw an article about how to make a "shop made" wood press, using plywood, threaded rod and either a press screw or bottle jack. The press was used for putting boards together for turing.
Now, of course, I can't find it.
Did anyone else read/see this article? If so, where is it???:confused:
"Recent article" doesn't ring a bell, but there's an illustration of such a press in "Woodturning with Ray Allen" by Dale Nish. And Malcolm Tibbetts' "The Art of Segmented Wood Turning" illustrates use of a pipe clamp against the ceiling.
A Q&D expedient could be to use a garage floor, a small sheet of plywood or MDF, a bottle jack, and a car or truck above. Try to keep the line of action as close as possible to the center of the glue surfaces.
Back when I learned, we used hand screws, which was a colossal PITA trying to keep them parallel.
If I were doing it now, I'd do Bessey K's or similar.
How about a cider press? Or one made with bench vise screws?
Wow, cider press and veneer press turned up a LOT of stuff! Thanks everyone.
