  • Congratulations to Dion Wisniewski for "Basketweave" being selected as Turning of the Week for 12 May, 2025 (click here for details)
Wood size for threads?
Windermere, British Columbia
Okay a technical question. If I’m going to make a lidded box and going to make the lid threaded, what size do I make the outside and inside diameter of the box and lid for threads to work. I understand for each size of thread it’s going to vary, but is there a formula or a chart out there that will give me something to start working off of ?
If you are using a tap and die you make them to the size for those
If you are hand chasing threads or using one of the thread cutters
Virtually any size but 1/2” to 4” diameters are the easiest.
The after the make or female section is done one is cut measure the and add the thread depth for the male or subtract the thread depth for the female.
I usually add a bit more and just cut until the fit.
You would think it would be a science but much depends on your threading style and how you measure. I believe making the tenon equal to the recess plus 75% of the thread size will get you close with a bit of a margin of error. Thread size for 1/16" would be .0625 so I would add .047" to the inside thread measurement. Allan Batty demonstrated an alternative approach to actually measuring in his video
View: https://www.youtube.com/watch?v=-0iEd0kD0S4&t=210s
Al,
This sentence seems like it would be a big part of your recommendation, but I can't quite extract the meaning. Would you try typing again? thanks.
And thanks to Glenn for asking this. I haven't yet taken up thread chasing, but I'm gonna give it a go this winter and this is one of my big questions.
Al,
I was scratching my head and kept reading it, I need some clarification too... @hockenbery
I use a jig so if I start with a 2" hole I touch and then go in .040 in two cuts (the end of the threads are now 2.080"). Now to make the male threads I start with the wood at 2.070" and take two cuts in, one at .020 and the second at .015 total of .070". This should give you a perfectly threaded connection.
Glenn, the video that Mike Peace recommendend is by far the best one on thread chasing. You do not need to be an engineer to chase threads. Allan shows you a simple an efficient way of fitting the lid without using calipers or a gauge. Your first step if you want to get into thread chasing is to watch that video 5 times.
