Wood turning capabilities?
Cleveland, Tennessee
Not sure if that is the right question. I have a stash of dried wood that is begging to be turned. Had a bad experience today in turning a piece of redwood. Even with a new Hunter Viceroy #1, there was horrible tear out. Is there any publication or chart that refers to what is bad/good/best/better for turning?
Generally the denser woods are easier to slice or scrape. For a clean surface, most softer woods need to be sliced with well sharpened tools. Any book that tells about the density of the woods that you're interested in using will be very useful. Dry redwood and western red cedar will give you immediate feedback about your tools and turning technique.
I understand that you have a good supply of dry wood, but you might be better served by turning green wood first. You will find it more forgiving and possibly more fun. I would also suggest that you find a local mentor or club to help you with your walk. It will speed up your learning curve
Redwood and other soft woods can be challenging. Sharp/sharp/sharp (a new Hunter #1 should be sharp - don't forget to rotate it randomly on occasion).
With softer woods I like higher speeds, slow tool movement. I assume you experimented with the edge presentation, direction of cut relative to the grain, etc.
Also, soaking the surface of a soft wood with some kind of sander sealer can stiffen the fibers a bit for perhaps a cleaner cut. Might have to reapply and let dry between cuts.
Question: turning what? Spindle, face grain?
Having someone else look over your shoulder and try cuts with different tools can be helpful.
