  • Congratulations to David Croxton for "Geri's Basket Illusion" being selected as Turning of the Week for February 2, 2026 (click here for details)
Wood type for pepper/salt mills and bowls?
Macomb county Michigan
Ok with the number of exotic woods that are toxic to some extent or another. What are some good easy to work woods for a starting turning? Say for a pepper mill and a salt mill for a set.
Toxic Woods
Glen, I would be a bit careful with Cherry. If you know where it's from and what type it is and how dry it is you maybe ok. For example if it's an Amur/Black cherry and it's not <12 Moisture content, salt may pull that moisture out and be heavily laden with cyanide out of the cherry.
If you have a Mother In Law you need to get rid of, this maybe a great method....:eek:
All I can say is do your homework and keep a copy of this handy http://vet.vet.purdue.edu/toxic/navigate.htm
Good Luck.
Many good suggestions so far Glen, and I agree with them. Most domestic hardwoods are good prospects for utilitarian items. Maple, Birch, Beech, Cherry, Ash, Sycamore, Walnut, Butternut, etc. I always coat the inside of my mills with shellac just in case though. Some think it is overkill, but I do it anyway.
Good Luck.
I've always heard from people with cattle that the leaves of the cherry tree can be a health issue for animals. The link you provided seems to point to the leaves as being the part of the tree with the highest risk. Many cooking utensils and bowls are made from cherry. I don't think there is any risk from using cherry for a pepper mill or for salad bowls.
Amur Cherry
Dale, last spring a friend of mine cut down a Amur Cherry(part of the Black Cherry family) and gave me the logs out of it. I spent the next few days making lumber out of it in my closed shop. Damn near killed me. The cyanide is in the sap and seeing it was spring time it was flowing well. The cyanide is volatile and ended up in the air of my shop so I was breathing it in.
This wood is now dry, but I sure won't be making Tooth Picks out of it!!!
Syd
I got a couple of pickup loads of black cherry from a friend that cut down a tree this last spring. It's piled on my shop floor and I'm constantly walking around it but I have turned a few pieces out of it already. I haven't had any problems but I'm not doing very much at a time either. A couple of pieces I turned green and I roughed a few more to throw aside for a while but that is over the course of probably six months.
