I find quite often after turning a bowl on a chuck or faceplate when I go to unscrew it I cant break it loose without jamming something into the chuck and rapping it. Most lathes Ive worked with a paper spacer keeps this from happening but the shoulders on the DVR shaft are so narrow it just cuts the paper apart and still sticks. My solution was to go to Home Depot and buy a 1 1/2” open end wrench and grind the sides down to 7/16” thickness to allow the wrench in between the head and the chuck. The face plates and the chucks all have 1 1/2” flats, and with the leverage and the index locked all it takes is a gentle push to break the threads loose, much better than beating on a cross pin stuck in a chuck to get a grip.
