1836 Revo lathe and equipment
Status
Not open for further replies.
Rome, GA
Hi guys, my name is Ron Vasser and I started woodturning a couple of years back. Last year I was diagnosed with a chronic eye disease where my optic nerve is deteriorating. I have lost depth perception and it’s becoming dangerous for me to continue. It was my favorite hobby but it has come to an end. I cleaned all my equipment and it’s been idle in my shop for the last year so it’s time to sell. I bought over $7500.00 worth of tools the first year and would like to sell everything for $4500.00. I still have things to add to this list like lots of wood, once turned bowls, chainsaw and blank cutting stand, oils, paste, waxes, finishes, green seal, 100 lbs. of paraffin, and more.
I live in North Georgia. Call, text, or email and I can furnish more info or pictures.
Ron Vasser
440 Collier Road NE
Rome, GA
rondv0021@bellsouth.net
706-766-4842
Laguna Revo 18/36 2 hp lathe 220 volt with built on ballast box and LED lights
2 ea. Live centers and cones
Revo vacuum bearing adapter
3 sizes vacuum chucks
Vacuum pump set up on tool cabinet
Hurricane HTC100 4-Inch Woodturning 4 Jaw Chuck Kit with Dovetail Jaws
Large Dovetail Jaws for HTC100
Extra Hurricane Mounting Jaws for the HTC100 Chuck + screws
Spigot Jaws for HTC100 Woodturning 4 Jaw Wood Lathe Chuck​
AXMINSTER CLUBMAN SK100 WOODTURNING CHUCK - 1.1/4" X 8 TPI
AXMINSTER WOODTURNING SK100 DOVETAIL JAWS TYPE C
AXMINSTER WOODTURNING DOVETAIL JAWS TYPE A
Axminster SK100 O'Donnell Dovetail Jaws 3-in-1 Set
Axminster Faceplate Ring For Use With Type A Dovetail Jaws
Axminster Evolution Series Tool Post 25.4mm (1") x 125mm
Axminster Evolution Series Tool Rest 100mm
Axminster Evolution Series S Shaped Tool Rest
Axminster Evolution Series Woodturners Smock – Xlarge
Axminster Clubman SK100 Accessory Mounting Jaws
Jaw Fixing Screws
Robust 14" Large"J" Curved Tool Rest, Standard Post
Rikon 1/2 HP Grinder + 1 Mega Square + 1 • 4-in-1 CBN Wheel 600 grit and 180 grit with LED lights + Wolverine Grinding System with VARI-GRIND jig mounted on tool cabinet with built on tool caddy
Carter & Son 5/8” Bowl Gouge with 16” Carter & Son Aluminum Handle
Carter & Son 5/8” Bottom Bowl Gouge with 20” Hickory Handle
Carter & Son 3/8” Bowl Gouge with Hickory Handle
Carter & Son 3/8” Detail Gouge with Hickory Handle
Thompson 5/8” Jamieson Signature Bowl Gouge with Hickory Handle
Crown REV237SK Revolution CRYO Cryogenic 1/2-Inch Spindle Gouge Blade/Hickory
Crown REV241K Revolution CRYO Cryogenic 3/8-Inch Bowl Gouge/ Hickory
+ more
Led Magnetic Machine Work Light IP65 Water Proof Flexible Gooseneck lamp 900 Lumens 120 Volt for Lathe Milling Drill Press Industrial Lighting
3M M-100 Series Versaflo Respiratory Faceshield Assembly M-107, with Premium Visor and Faceseal with c-pap hose and air pump
Easy Wood Tools 4-1/2" Diameter x 1-1/4" - 8 TPI (F645) Bright Aluminum Faceplate
Sorby Micro Spiral Tool
3/8" x 16 tpi Texturing Tool
2ea: CSLU Lathes MT2# 60 Degree Point Morse Taper Lathes Dead Center,Hard Alloy
No. 2 MT with 1-Inch Crown Super Wood Lathe Drive Center​
Stuart Batty Angle Gauge One
Spring Inside Outside Divider Caliper Set Measures 8 inch Machinist Tools 3-pack, 230mm Leg Length​
Beall 1-1/4" x 8 TPI Spindle Tap
Einstein Tool Co. 1/2" JT33 Drill Chuck 2 MT Arbor/Mount for Lathes and Drill Presses Two Keys
1-1/4" x 8 TPI #2MT Hold Fast Chuck Reversing Adapter
Beall® 3" Bowl Buffing Set of 3 Buffs​
Beall buffing system with mandrel for lathe spindle and 3-8” buff wheels
Status
