Having an issue where the USMC Black leather dye is bleeding through the coats of wipe on poly on a couple of finials. I applied two coats of the dye, let dry overnight - it was dry to the touch. Covered it with wipe on poly. The rag used for the first coat turned black, which I suspected might happen. I've now applied 3 coats of wipe on poly, with plenty of dry time, even on the last coat just applied, there was still some black on the rag.
Is this normal? Did I not let the dye dry enough? Fortunately, the amount of black on the rag has been reduced each time.
I'm really glad that my decision was to finish the finials before gluing to the box they will be on, as this bleed would be catastrophic.
