- Joined
- Dec 22, 2006
- Messages
- 7,117
- Likes
- 9,858
On bowl blocks, I've been using my 6x48 belt sander to get an initial flat spot for faceplate mounting. I can get a 10" section of the wood flat, and then turn it over to get as much as 20". My lathe swing is 16", so this is satisfactory for my purposes.
.....there is one problem with this, though......
I have to sand a rather large surface area of the bowl block, even though I may only install a 4" or 6" faceplate.
I'm wondering how many other methods of getting a small flat spot on the bowl block you are using.
Hand held planer?
Disc sander?
Mallet and chisel?
What works for you?
Hand held planer?
Disc sander?
Mallet and chisel?
What works for you?
