Gun Drill Source?
Evanston, IL USA
The tool freak in me wants a gun drill now that I have seen Trent Bosch use one. Bosch and his daughter Kailee, did demos all day yesterday at the Robust factory in Wisconsin. Bosch only mentioned Ebay as a source, but there must be other sources.
Any ideas?
EBAy is the only source I found but them I didn't look real hard. What did Trent do with it. I was using them to drill through a goblet stem. Broke the first one. They are apparently very brittle.
Evanston, IL USA
Bosch uses a gun drill to bore a 3/8" d straight hole to finished depth in his hollow forms, by hand.
He made up the holder with the air valve.
You can find some excellent ones on eBay in the $20 to $30 range the last time that I looked which has been a while. Buying a new one would be considerably more expensive.
John if you broke a drill you may have been running the lathe way too fast or not running compressed air through the drill or using too much force. Also back the drill out frequently because the chips can clog up the hole.
The first time that I used a gun drill was about a dozen years ago when I took a two-day class from Trent Bosch on creating his vessels of illusion hollowforms.
Evanston, IL USA
And here is my impromptu adapter...
Next one will be longer...
Thanks Clifton.
Thanks Bill, but like you said, it "has been awhile" since Ebay had drills in that price range of a decent size.
Springdale, Arkansas
I saw a Trent demo and thought I needed a gun drill. A search on ebay found a USA made quality drill around 3/8” that had been resharpened with the wax still on the tip. I gave $20 or so delivered. Next step was to make a handle out of some scrap delrin plastic. It worked perfect.
So...I can drill almost as fast with a 1/2” spindle gouge and I don't have to hook it up to a air chuck. I never use the gun drill....but I might some day so its not for sale.
Emiliano Achaval
Maui, Hawaii
hawaiiankoaturner.com
I have never use a gun drill, nor do I know what the benefit of using one is. Remember I'm isolated in the middle of Pacific here, like that tv show Lost... I know thats how gun barrels are made, so I'm guessing you could drill to depth very easily with one... Maybe somebody can point out to a video or a little explanation might shed some light on it. Thank you, Aloha
Not being a production bowl turner I just use my bowl gouge or detail gouge to drill out the center. On occasion I have used a 1" twist drill that I bought but I use it in the tailstock.
The gun drill has an airway to the tip. When connected to a compressed air it blows the chips out as it drills.
This allows drilling a hole as deep as the bit’s length in one continuous push. No need to pull the bit back to clear the shavings.
It also is pretty good at drilling a straight hole in endgrain.
If you use air tools a lot it is a quick way to drill holes for HFs
If you have to turn on the compressor and bring a hose to the lathe it is a slow way to drill holes.
Evanston, IL USA
And, the air, or "coolant", is the way these drills must be used, if not, as I was told by a manufacturer, the carbide tip will likely break off.
And, I did find a "manufacturer refurbished" drill for $35 with free shipping on Ebay. That's a lot less than the $90 from the manufacturer or MSC.
Peoria, Illinois
I've had just the opposite result. Air or coolant will prevent breakage? I've used the same one with no air or coolant for about 10 years, with no breakage. Of course anyone could break it with abuse, but I don't leave it buried in the wood until it gets hot enough to discolor. I peck drill with it and keep the waste cleared off. Air does not clear out wet wood end grain curls. They stick in the flute after just reaching a little depth. Of course just my experience, evidently Trent has better luck.
False. Air or coolant will prevent breakage? I've used the same one with no air or coolant for about 10 years, with no breakage. Of course anyone could break it with abuse, but I don't leave it buried in the wood until it gets hot enough to discolor. I peck drill with it and keep the waste cleared off. Air does not clear out wet wood end grain curls. They stick in the flute after just reaching a little depth. Of course just my experience, evidently Trent has better luck.
When used as intended for drilling deep, straight, and precision diameter holes a coolant fluid is necessary. Not using coolant when drilling deep holes in metal will ensure breakage (which isn't quite the same thing as saying using a coolant will prevent breakage). The fluid serves two purposes, it maintains a constant temperature at the cutting tip so that the diameter remains constant and it flushes the swarf out of the hole so that the drill won't jam and break. Start and stop drilling won't work for precision diameter deep holes. Woodturners, on the other hand, don't need precise diameter holes nor perfectly straight holes so using air to help clear out the chips and quickly drill the hole are the only advantages. Otherwise, a spindle gouge or twist drill will work just about as well.
Evanston, IL USA
Like I said, that was a quote from the manufacturer--- maybe you should show them how to do it.
nj
Any ideas?
Some gun drills are single flute and some are two. All the ones I've seen are straight fluted because the coolant carries the chips out and because of that there's no need to continually relieve the cut to clear chips and re-lube the drill.
Sterling makes gun drills. There are a lot of makers. For the life of me I don't see the advantage in woodworking. Unless it's for very deep holes. In that case, the relieved body of the gun drill might offer less heat build up from friction.
It'd make for a lot of airborn dust if one uses compressed air.
I just push the whole tail stock in and out. It's a habit I picked up as a machinist drilling deep holes in Molds. Peck a bit, Pull the tailstock out, lube the drill, clear the chips, then slide the tailstock back in and peck some more.
However when drilling wood it is really fast because the clips clear themselves when I pull the tailstock out and I don't lube with wood. I suppose I could use wax but never found it necessary.
Evanston, IL USA
Right, Sterling does make gun drills, and they make the best drills for wood drilling and guys who absolutely have to get a straight hole. If you were a woodwind instrument maker I think you'd then see the advantages that you haven't been able to see yet.
Hampton Roads Virginia
Tom, This was my quick and dirty, for proof of concept... It worked, If I were to make it again I would make it a bit longer, somewhere between 6 or 8 inches.
This one is 2 3/8th by 3 3/4's because it's the piece of wood (maple) I had at the time.
As I remember...
Turn between centers, tenon each end.
Grab tenon, drill to fit end of gun drill.
Reverse, drill and tap for air fitting (1/4 NPT)
Soak threads and end grain w/ thin CA, retap
Mark, drill and install threaded inserts.
Teflon tape, ball valve and air fitting.
20210125_211451.jpeg 20210125_211512.jpeg 20210125_211555.jpeg 20210125_211957.jpeg
Needed some light scraping to fit drill, Threaded inserts had to be filed/sanded flush. Thought of putting a gasket in the bottom but don't feel it's needed, a bit of air leaks by, but not enough to worry about.
Hope this gives you some ideas.
cc
Edit... my NPT was off, thanks Al, for the catch...
