We just finished moving the forums to a new hosting server. It looks like everything is functioning correctly but if you find a problem please report it in the Forum Technical Support Forum (click here) or email us at forum_moderator AT aawforum.org. Thanks!
Johnathan Silwones is starting a new AAW chapter, Southern Alleghenies Woodturners, in Johnstown, PA. (click here for details)
Congratulations to Peter Jacobson for "Red Winged Burl Bowl" being selected as Turning of the Week for April 29, 2024
Y'know, maybe a half-page or more of a technique related to the production of a piece would be a worthwhile addition to the occasional article in the Journal. That way the whole article wouldn't have to be labeled for beginners. No need to create a separate column or label articles (or their target) that way.
Accidental learning comes from accidents. I'd rather learn vicariously. Not sure the article in question is going to prevent problems if those first two confusing illustrations are followed.
I read the article and went back and looked at my bowl gouges and discovered that my own grind had actually morphed from Ellsworth's into Jamieson's. Mostly because I like long wings. It also occured to me that this might be the root cause of a problem - I like to use the gouge in sheer scrape position on the outside of a bowl and very gradually I've found myself using the gouge almost upside down. I'm going to have to shift the angle I grind the wings at to correct for that. The article helped me think that through.
