john lucas said:
My argument against using the rough out gouge for bowls is that it's too easy get the cut up on one of the upper portions of the u. This then becomes an unsupported edge and the wood pulls it down and you get a catch.
Well, you bring up a good point.
Somebody can suffer a thoughtless or careless moment and louse up almost anything. Then get defensive when the laws of Physics and good turning practice are presented to suggest what happened and the way to avoid repetition. Tang-phobes, please take a long nail and insert it in the end of a stick, which you may make as long as you care to. Lay the first half inch firmly across a fulcrum - tool rest will do, hold the handle, grab the end of the nail with pliers and twist downward. If you've got a hammer, strike it down anywhere forward of the fulcrum. Where's the bend?
The weakness in the straight-across grind as you indicate, is that it has almost no poke, merely peel. Means the entry angle must be on a fairly shallow slope to start the shaving. Definition of a peel. When there's a round contour on the edge of the gouge it's easier to poke in slowly and transition from narrow to broad peel, even when working 90 degrees to the grain, as on a vertical portion of a bowl. Answer can be to take up a gouge like the 35 in
http://s108.photobucket.com/albums/n28/MichaelMouse/?action=view¤t=35mmGougeRounding.flv or the forged you mention,
http://s108.photobucket.com/albums/n28/MichaelMouse/?action=view¤t=Gouge101.flv which give a bit of curved poke for starting, and clearance in two dimensions based on their geometry. Of course the round section and the necessity of not burying the nose and getting a catch does limit the width of shaving, which translates to depth of cut.
When we don't want a great depth of cut, no such impediment. We have all used a skew or beading tool to cut across grain, and we know that the two things we don't want to do are take too broad/deep a bite with a straighter edge, and as always we don't want to allow the point of first contact to become the deepest part of the cut - get under something. Why we cut downhill, after all. We can take a thin cut with the rougher by presenting the one curve we have on the straight-across rougher to make a controlled entry, and then roll up on that edge you fear so much, skewing the unrelieved corner to follow the cut as we do. On a bowl cut that keeps the trailing point above the curve of the piece, because we're cutting above centerline and can't go through our toolrest, and
also because we are cutting smaller to larger, which places that corner in the smaller diameter. If we have the bevel on the surface, the gouge can't rotate the corner into wood, because it has the leading part and the constant angle bevel pushing back and being pushed outward by the rotation of the piece. Problem of cutting at 90 degrees to the grain with the roughing gouge is a bit like designing a fighter, where they can be so stable they're not maneuverable. Narrow gouges with variable grinds maneuver well because they are unstable, like the best fighter designs.
Our task is to fly each gouge as it wishes to be flown, or risk an unusual and unrecoverable attitude. Never, ever forgetting the first rule that when the houses keep getting bigger, we should pull back on the stick. Or, we could do what some suggest, and punch out.
