Joey Butcher
Hi Guys
New to the forum, thanks for your hospitality.
I started woodturning to make hickory handles for my Tomahawks.
Heres the question: How do you turn a handle that isnt quite a round shape ?
Heres images of what I'm trying to do ( these are pro made handles ).
Any help ?
Ovals can be turned on three centers/both ends. That's what you normally see on an axe, maul or sledge. Triangular involves isosceles triangles, not in-line offsets.
Two free pieces of advice, based on Ed's tutorial. There is no need whatsoever to turn at 2K. Remember Newton's second law. Half or less speed than that will do the job, and it'll actually help you in getting a smooth handle, because you'll be taking a shaving, not dust. Second is to use a cup center, and tap it in to engage the cup. That 60 degree point may be fine for metal, but it will run if you have a catch and screw things up much faster than the point and cup. Of course, you'll have much less energy to rip it out if you turn slower, too.
Last piece of advice is to remember that you will get fairly sharp edges either end of the oval you turn. Expect to take that off by re-centering, then sanding the two minor ridges away.
Best choice of all, of course is to use a horse and shave.
I turn hammer handles on 4 centers. Sketch the radius roughly. then set a compass so it matches that radius draw a circle. After you have drawn the circles you will have the center points for your turning. If it needs to be tapered then you may have to move the center points on the other end of the turning.
Tallahassee FL
Except for the challenge of off-center turning, I second the motion of using a ["shaving horse"] and a [spokeshave]. Google is your friend, and so is [Roy Underhill].
BTW, and not trying to start an argument, I think axe handles, golf club heads, Olde Dutch shoes, and such, are usually made with a rotary cutter on a pattern-following contraption, turning very slowly.
Thanks Guys !
I appreciate all the helpful advice. I'll keep you posted on how it goes.
Joey Butcher
Cleveland, Tennessee
I would shape them on a flexible disk sander. I do this with cigar-shaped cork fly rod grips.
