Moving Large/Heavy Pieces of Wood
Millington, TN
Interesting ideas. But I notice that no one talks much about how to get a tree trunk out of your pickup or off your trailer. :)
If log is too heavy to lift then tie a chain around the log (or use sturdy log tongs) and then around a sturdy tree. Drive the trailer forward as the log gets pulled off the trailer & dropped to the ground.
I had a huge piece of myrtle in the back of my cargo van. Drove some steel stakes in the ground, put a chain on the log chunk, and drove off. Worked fine. Some times you can lever it up a bit and put a round dowel of some sort under it and it will roll a lot easier.
Sebastopol, California
For harvesting on uneven terrain, I've gone out with friends who had a little DR Power Wagon and it was a lifesaver. Basically a powered wheelbarrow. Here's a link to look at:
For boosting logs up onto the cutting cradle on my tailgate, I modified an inexpensive ATV lift from Harbor Freight. It's a little clunky but it gets the job done and saves my back. Wish I'd done this _before_ the herniated disc...
I like how you used a cut off to block the wheels! And the 2 by 6 to keep it from rolling off the end.
Peoria, Illinois
This is the biggest one I've handled. The client brought it on a trailer. Pry bars and black pipe got the 4' long log off the trailer. Kinda sounded like thunder when it hit the ground.
