- Joined
- Dec 22, 2006
- Messages
- 7,121
- Likes
- 9,875
Have you ever picked up an infrequently used lathe tool and wondered how much use it's seen since it's last been sharpened? Should it be sharpened, or not? For many years, I've been sharpening every tool I use every time I use it. Sometimes I've been sharpening tools that really don't need to be sharpened at all.
.....And test cutting doesn't really tell you how well your tool COULD be cutting......it only tells you how well it IS cutting. For those of you who will test cut and say it's cutting good enough, the previous statement is an important thing to consider.......those of us who have a little time under our belts, know darn well that "good enough" is just an excuse for not finding....."better"!
I have been using binder clips to show which tools have seen minimal use since it was last sharpened. This won't help much for those tools you use frequently, but for those you use only occasionally, it can, at the minimum, DOUBLE the life of that tool.......not to mention that it'll not only save you money on tool costs, but save you time by not sharpening tools that don't need sharpening.
OOC
The tools in the photo with spring clips attached, do not need sharpening......and I'll KNOW this, no matter how long it's been since it's last been used.
OOC
