Beating a dead horse I know so I thought I'd do a poll.
I have a set of axminster O'donnell jaws that come in 50mm - (2inch)
38mm - (1 1/2")
25mm - (1")
That is when the jaws are perfect circle/ optimal size. I want to make some small jam chucks for some 3 -4 inch bowls I need to finish turn that have various sized recesses and tenons which is why I was going to make a jam chuck for each size jaw. I'll be making them out of hard maple and would like the most stability for re-usability.
**EDIT**
I keep calling this a jam chuck, I guess I should be saying friction drive chuck because I'm talking about the type that you put inside a bowl with a piece of drawer liner or foam and use the tail stock to hold the bowl on.
Not the kind that has a precision fit of the rim into a groove or bevel and "snaps" on.
38mm - (1 1/2")
25mm - (1")
**EDIT**
