Turn a one-piece yo-yo
Colorado Springs, CO
Great video Ed! What did you use to insert in the recess on the yo-yo? Again thanks for the posting, got to try it.
Thanks...are you referring to the black O-rings or the decorative counterbores on the sides? The O-rings are "EPDM"...relatively inexpensive and easy to find, hold up well after years of use. Try to avoid the less expensive "Buna-N (Nitrile) plumber's O-rings, as they will crack and fall apart if exposed to sunlight. I'm still working on the side decoration counter bore areas...it takes 3 or 4 days for the epoxy resin I'm using to cure. I normally will use handmade epoxy resin or polymer clay cabochons to decorate the sides. Will post pictures of the finished yo-yo (shown in the video) soon.
Okay, here's the completed yo-yo from the how-to video, fully finished. The side cabochon embellishments are made with epoxy resin & black alcohol ink coloring, and a top layer of chunky holographic glitter...using the lathe-turned counterbores as a mold for the epoxy to set up in.
Great video!! Thanks for sharing. Have you ever tried UV cured inlays for the sides? I tried one on a yo-yo and it works pretty well..
I've tried UV resin several times, but could never get the stuff to cure completely...ended up with a sticky mess. The two-part resin I use air cures to finger-touch hardness in about 12 hours at 70 degrees. Faster if warmer, but it'll take at least 24 hours to fully cure.
A coat of clear epoxy resin over polymer clay works for cabochon making as well...
Nice. I don't think I would be able to be that precise with the turning. I did find out a long time ago that the sides had to be exactly the same weight, like down to 0.01 gram or so, otherwise it would spin side wise. Another toy I played with but never mastered....
In my experience, the grain and density of the wood has the most influence on balance. Burls & spalted woods generally don't work well. Hard Maple, Osage, Purpleheart, Bloodwood, SpectraPly and the like tend to work best. My favorite wood for yo-yo turning is baseball bat factory reject Maple. Another balancing pointer to consider: the two rubber o-rings tend to add stability to the yo-yo's performance, and will sometimes get a out of balance yo-yo into a useable state. As the o-rings stretch, you can even use two different diameter rings to help compensate for one side of the yo-yo being heavier than the other.
Tom Gall
Hillsborough, NJ
Enjoyed your video, Ed. A question or two about your process ... I know you probably have good reasons for your methods, but ...
  1. Why don't you wrap your protective masking tape while the yo-yo is still mounted on the chuck? I think that would be a little easier and quicker (a 3rd hand). I thought I noticed a very minor, mostly insignificant, wobble when you reversed mounted over the tape.
  2. Maybe you could use another chuck with something like spigot jaws (1"closed) to expand into your drilled hole (1-3/8"? or 1-1/4"?). Probably would take the same amount of time or less to change chucks than to wrap & unwrap the tape. And may be a little more accurate.
Just my 2¢. :)
Just my 2¢. :)
Wrapping the tape while on the chuck would certainly work...old dog learns new trick :cool:
The side counterbores are just one form of dozens I use for decoration...probably 5 out of 6 I make don't have that feature. But yes, it would probably work for those that do have a counterbore in the design.
Montfort, Wisconsin
Your precision and attention to detail certainly are reflected in your work. Attention to detail in your photography background shines through. Very nice, thanks for sharing.
Seattle, WA
1/4" to 3/8" in diameter. Be careful not to make the axle too thin, as it might break or "burn-through" with use.
PSA: if you haven't thrown much before, it's super critical to not let the yo-yo string become highly overtwisted on a wood axle. This often happens when new players would rewind the string on the yo-yo, holding the yo-yo on one side and winding over the other, but can also happen from some tricks. E.g. skilled players would alternate their loop-de-loops on the inside and outside of the throwing arm to keep the net twist neutral. Failing to keep the twist out will eventually either 1) groove the wood axle which then kills that string and all subsequent strings instantly or 2) even weaken and break the axle. With the old Tom Kuhn yo-yos, the wood axle was replaceable so this was annoying, but not the end of the yo-yo.
Of course, since the early 00s brought on the crazy high skill bearing yo-yo era... most of that is historical knowledge re: kids these days. ;-)
