I've got an older vicmarc vl300 I bought in January from a local guy that had changed the spindle bearings right before selling it to me. In the last month or two I'm seeing and hearing some slop that presents as the spindle will move slightly in and out of the frame. If you hold a chuck and push/pull you can feel it move. When turning, as I put pressure on a tool towards the headstock the same movement can be felt and heard.
Also, the spindle stop pin sounds like its rubbing on the inner piece (headstock pulley?) that has the holes to lock the spindle. I hope that makes sense. It seems like something has gotten loose and I was just hoping for some guidance on what to look at when I pop it open to look. Thanks.
