I'm trying to repair a vm100 and asking if the insert on this chuck is a taper with a set screw to lock it in, or threaded. Iif threaded, how is it removed.
info I've seen is not definitive
Thanks
Thanks
I drilled a shallow hole (just a divot really) for the insert set-screw to sit in, helps with this problem.If I try removing it with the key it will occasionally unscrew the insert because the set screw doesn’t lock my insert in place very well.
Not all Vics have inserts. My VM120 is direct threaded. Wish it had a grub screw.The Vicmarcs definitely have threaded inserts. The old one are just heads, the newer ones have a set screw that tightens against the body of the chuck.
If it seems really stuck I would likely use the chuck jaws to clamp onto a well supported board and then use the bar or a spanner wrench to unscrew.
