Blade Kerf and getting the needed kerf in the wood?
Don’t try to slide the board, instead set up a stop block for the first cut then add a shim of the proper thickness between the stop block and the board and make your second cut. Since the blade will tend to deflect when only trimming off make sure you have a sharp blade and cut slowly. To determine the thickness of the shim required divide the amount to be removed by the cosine of the miter angle.
THANK YOU! This was what I was looking for: COSINE OF THE MITER ANGLE. I didn't think it would be that simple...but I was hoping it would be. I am already set up to do this. I just needed a simple way to determine the thickness of the shim. I haven't slept in a week here, so, doing any trigonometry to try and figure this out on my own here, wasn't going to happen...
I did pick up a full kerf blade. It will just make the process easier and faster here, as the 5/64" blade is nowhere to be found now. I have a bunch of things to make, and this blade is just a slight bit wider than the inserts, so it should work well for the use case.
When I first tried celtic knots I did the partial cut as you are talking about but when inserting the inlay it would scrape off most of the glue making a poor glue joint. I then tried cutting all the way thru, but that presented the problem of how to maintain alignment while the glue cures. I have a photo of the gluing fixture but this appears to be the wrong time to send an Email to myself to get a .jpg file onto my laptop computer. The point 2 is exactly what will happen if the insert material is not the same thickness as the saw kerf, I know because I tried to use a thinner insert. I have the ability to make insert material to the exact thickness required, however I then had the bright idea that the insert should have the same grain orientation as the primary wood and that may be a method that you could use. To adapt my method to a table saw attach a board to the cross cut guide that is wide enough to not get cut off then clamp a stop to the end of the board and adjust for the required thickness. The picture will probably get through some time tomorrow and I will send it then.
Aye, I head you about it squeezing out all the glue. Someone on another forum said they will usually shim the blank with a couple thicknesses of paper, or thin cardstock, to widen the kerf just a bit to allow for the glue. This saw blade I picked up is just a smidge wider than the 1/8" stock (which I did not cut myself, I can reasaw, but I do not have a thickness planer, so I buy my microlumber from woodcraft or rockler most of the time. Its not exactly cost effective...but, not only do I not have the funds for a thickness planer, but I also have absolutely nowhere to put one even if I could afford one. So the stock is as thick as it is, not much I can do about it.) If for whatever reason this blade still isn't leaving room for glue, then I can use that thin cardstock tip.
So, I have been thinking about doing this. My main blade, which is about 3/4" wide and has more than your usual number of teeth, leaves saw marks on the surface, which are enough that, I think I would have to find a way to chisel that smooth first. I have other blades, most resaw, one a 1/8" blade for doing curving cuts. I can't imagine the resaw blades working well with these smaller pieces of wood. The 1/8" blade....I don't know if I could keep it truly strait.
I'm curious, what kind of blade do you use for such work? If I could find a blade that did not leave notable saw marks and I could cut strait with, I'd give this a try. I have a Jet JWBS-14sfx, 116" blades.
By far the best blade I have found is the Lenox Diemaster 2. The blade I use is 1/2” x .035”, 3 tpi. Your bandsaw needs to be set up properly and you need to feed the stock slowly and consistently to get a smooth cut. I get glue ready surfaces when cutting veneer but not sure it is smooth enough for a joint that would be viewed edge on. That’s why I suggested finishing up with a disc sander or hand plane.
You ever heard of a digital caliper? I'm pretty sure it is capable of measuring 128ths, as I have pretty reliably thick 1/64" thick veneer, and the 1/128 measure on my calipers is just about half that. You think its not possible to measure as 128th??
Yeah- I have seen 128th's measuring tools, but more commonly once you get down to sizes that small, they've already gone to decimal (10th's, 100th's, 1000th's 10000ths) - 1/128 of an inch is a tad under .008" I HAVE seen digital calipers that read in 128th's but those are often the cheapo chinese makes on Amazon and as mentioned, once we're talking increments that small, might as well move over to my Starrett and start measuring in thousandths... I never saw much point in measuring that small with wood anyway , since wood moves and even a small piece can move more than 1/128th of an inch just from humidity changes.
To other points: The only reason you need a specific size of blade kerf when doing Celtic knots is when you are not doing thru-cuts , and generally in that case I'd say you'd go by the saw kerf and then cut your filler strips to the width of that kerf (as mentioned, thin strip jigs do the trick nicely as long as your saw is set up properly with a sharp blade) Me, I used to do it that way, I'd cut the inserts just a hair THICKER than needed and then hand sand (or hand plane) down to a nice slip fit into the kerf - It helped that I was using a fresh brand new table saw blade so it didn't leave very rough edges in the kerf... But then as I said, I stopped bothering with those designs since they were way more work than what they were worth, and there were much easier and more popular designs and forms to do.
*edit* Huh, wow - in the time it took me to type all that it appears you already found your answers, so.. Moot point, I guess.
I'm confused...there was an 8 hour gap between my last post, and yours? :confused: I mean, a day plus since the answers were actually provided? I don't really understand this comment...
I am not really sure why so many in this thread are latching onto the 128ths thing. Let me just simplify: I have 1/8" thick inserts, from boards I bought pre-cut and pre-planed, for another project I abandoned. They don't fit the kerf my blade cuts naturally. Doesn't matter if its 3/32", 13/128", or 25/256"... The inserts don't fit. That's all that mattered, the inserts don't fit. The jeers about how I am measuring, are just childish, and to be perfectly frank, I don't quite understand that in a community of a bunch of grown men. 🤷‍♂️ Anyway...
The point of the thread was is there a way to adjust the blank being cut, just the right amount, to widen the kerf with a thinner blade by making multiple cuts? I knew there was a way to determine it, my brain just wasn't having anything to do with math the last week. Well, DID get an answer to that, thanks to Mike Seiser. I may return the full kerf blade here, if I am able to get sufficient cuts with my existing blade. That was the help I needed. Thankfully, one of you understood the question and provide a useful answer without any of the rigmarol over whether my measurements were accurate or not. Thank you much, Mike.
Thanks. I found this in over a 12' length. Not sure if they make one that would fit my bandsaw. Is this a wood cutting blade, or a metal cutting blade? I actually do have a metal cutting blade, its a Lenox "Classic Bimetal", has 10/14tpi. I originally bought it to help me cut unruly materials like trustone or inlace acrylester blanks. Brittle, and they were tough to deal with when the blade had fewer than about 10 tpi. Currently, my bandsaw is set up quite well for this blade. IT does not waver, and all the guide bearings are about as tight as I can get them without unwanted contact with the blade. The distances are 1/16" or less for all guides. The feed rate with woods, though, has to be very slow with this blade, it does not cut fast or even at a moderate speed. The most I generally use it for with wood is to cross-cut pen blanks down to size. I used to buy these "bricks" of trustone, usually 1.5x1.5" or 2x2" around, 6-7" long, and I would rip them down to 3/4" around segments, or smaller pieces for segmenting. The blade works well with those hard, brittle materials. It actually works fine, generally, with wood...it does leave sawmarks, but, really, the only issue is the need to maintain a very slow feed rate. I guess, I'll just give this a try with some scrap wood, and see how accurate, and strait, I can get the cuts. Maybe this blade will work.
That was sort of what I was aiming for originally - Was there some reason why you could not just sand/plane/whatever the INSERTS to fit the kerf being cut? As opposed to trying to cut a kerf to x width. Not a criticism in the least, just curious if there was some reason that the inserts could not be "shaved" down... which would save needing to get a precision cut kerf?
And lastly I wasn't making any jeers (though I can see where others may have, from reading other posts) about how you were measuring, I was just saying I HAVE seen calipers that measure in 128ths (even digital) but *for me* I'd just as soon switch over to decimal by the time my precision needs exceeded 1/32" (Easier to calculate in my head a need to take away .0075" than wrap my brain around needing to take away 1/128")
Finally, as far as my late edit - I'd gotten a pop up that other replies had posted since I'd started typing , just as I was submitting , and evidently it had gotten to page 2 already (I was replying on Page 1, didn't realize there was already a page 2 to this thread...) Hence the follow up edit , Looking at date stamps (Just now, not this AM) all I can think is someone else posted a reply from page 1 as well, then found page 2 and deleted their post.... leaving a considerable time gap..
I get my blades from https://www.bandsawbladesdirect.com/lenox-diemaster-2-bi-metal-band-saw-blades. They make any size you want. The Diemaster 2 is for both metal and wood but I don’t cut metal on my bandsaw.
Well, I didn't think measuring down to thousandths for a blade kerf was going to matter. I had it on fractions, kept it on fractions...that's all? 🤷
Anyway. I have a hand plane, however it needs to be sharpened better, and I'm not skilled with using it (bought an old one in mid december, have worked on sharpening the blade a couple of times here, but it is not cutting nicely...and I don't want to leave a bunch of digs in this wood trying to think it out. Further, I kind of wanted the 1/8" thickness for the items that will be using it. Originally I was even thinking of using some even thicker stuff, but even with a full kerf blade, at least originally, I was going to have the same problem: What is an easy way to adjust the offset of the blank to widen the kerf accurately. That's all I really wanted, a quick, accurate way to shift the blank for the second cut, without risking overshoot, and without having to shave off 100 tiny little shavings then check until I got everything right (which would mean, taking the blank off the sled, checking the insert fit, trying to realign the blank on the table, etc.)
I think with the hand planer, I probably don't have the right kind of stones, and my sharpening technique is very...novice. I have only two stones and a leather hone, vs. most of the skilled woodworkers out there such as Paul Sellers, usually work through three and then the hone. My hone is also brand new, and hasn't been worked in enough yet. In any case...blade cuts, heck, lot better than anything I've sharpened this far in my time as a woodworker (maybe a bit under 5 years now), but it doesn't shave well enough. I have very little skill with hand planing in general too, and this stock is already fairly thin (at least, for me, a real novice at this aspect of woodworking.) So, I know its possible to thin the stock...I just don't want to ruin it, and, I do like the thicker stock for the use case.
Duly Noted. Curiosity sated. :)
What about Sandpaper on a piece of MDF or Melamine (for flatness) A good quality sandpaper such as 3M's Cubitron (I'd probably suggest 150 or 120 grit) can remove .007" very (amazingly) quickly just hand rubbing it if you lay it out flat and then a bit of 2 sided tape on the veneer (for fingertip grippy-ness) and then just work it in circular motion , can very quickly take down a few thousandths at a time to fine-tune a fit, and maintain flatness of the veneer (I've been known to use similar method to fine-tune mitered corners on picture frames just to get a perfect 4 corners fitment) - no hand planing needed. Just wonder if you'd maybe considered that..? However I can see that having a jig set up to work with your specific blade and sled to make 2 cuts to get that perfect kerf could also be quite a bit quicker, especially if you are using veneers that have a very consistent factory thickness. (if they didn't have consistency then setting up a jig would be pointless, I'd think?)
I suspect you may find with some experience that once you have your first blade sharpened properly (takes a lot of practice to do freehand honing- same as with turning - building muscle memory and all that) that you'll very often only need to go to your final grit and then stropping (Thus, only one stone needed, really) Only time I will drop down to coarser grits (with chisels too, as well as plane blades) is if I have a particularly troublesome spot or nick , after I got things sharpened up, OR if I am trying to restore an original bevel (because the secondary bevel has grown too wide) but that's rather beside the point, I suppose - as with most other things - practice makes perfect, but doesn't solve the immediate problem at hand.....
Interesting. I was there earlier. I guess, when I choose my blade length (9' 8" or 116"), then the option to get a 3tpi blade disappears. I'll give em a call and see what they can do.
The .025 thick blade is not available in 3 tpi. The thicker .035 blade is available in 3 tpi or 4 tpi. Either should work ok.
Back in the day I had quite an extensive woodworking shop/business. Jon's problem would have been trivial to solve. Cut the slots with whatever blade makes consistent width kerfs. Then make insert's thickness to the kerf width less a few thousands for glue clearance. Problem solved. The inserts would been sanded to thickness on my Italian wide belt sander that was very accurate by woodworking standards. It makes no sense to me to try and cut slots to purchased insert thicknesses because those are very likely not to be consistent.
If you're into CNC and resin fillers you can do any variety of celtic knots.
BTW, I sold the woodworking business (which included production woodturning) not because it wasn't successful but because I owned the building and we got to the point of running out of space and zoning prevented expanding the building. So the decision was to switch to metal machining/engineering which has a much higher return on investment per square feet of shop space.
This is what I've been pursuing.
As for the rest... 🤷‍♂️ If I had the equipment, sure, trivial. Lacking a CNC machine or any of the other tools a wealthy shop would have, I'm trying to make do with what I have, or can get very cheaply. If you have every tool you could hope for, sure, this problem would be trivial. Not everyone has every tool they could hope for, though...
It seemed to me you were trying to adjust kerf to fit the insert thickness rather than make the insert fit the kerf. Yes, I had quite a shop. But it wasn't always that way. I built a thickness sander very similar to the one Don W has listed in the for sale sub-forum right now. My sander cost almost nothing to build with scrap yard pieces and turned out to be a money maker for me. That homemade sander could make precision thickness inserts. Later I bought the Italian abrasive planer/sander. That business supported the family with less equipment investment than most serious hobby turners on this forum have.
As to having a CNC, we've gotten to the point that CNC's are not a sign of a wealthy shop. Nope, these days you can have a fairly good wood cutting CNC (or maybe two) for less than the price of a high end wood lathe. Then add in all the accessories, gouges, sharpening equipment, hollowing systems, etc, etc and you're in pretty deep for a hobby. A $5K CNC will do any turning type work I've seen on this forum. My CNC's only came after I moved from woodworking to metalworking. I did find wood "turnings" could be more profitably done on a metalworking CNC so that became a nice sideline from cutting metal.
I don't want to reduce the insert by 1/32" though. I want it thicker. I could reduce it, but then I don't quite think I'd get the look I am after. Just because there is one way to do something, does not mean that is the only way to do something. Thinner loses the look. To be perfectly honest, I've been wondering if I could sandwich these 1/8" thick boards with a layer of 1/64" veneer on either side, to make these loops or rings in the finished product look even a bit more interesting. So long as I can figure out how much to shift the blank to cut exactly the kerf I need, I should be able to. That was really what I wanted out of this thread.
As for shop equipment. I don't have an income from this business yet. Anything I spend on the business just increases my losses right now. So I'm not in a position to spend money, even $500-600 for a very low end super entry level CNC machine, let alone another FIVE GRAND on a CNC that will "turn anything." Heck, spending $60 right now on a blade is not really what I want to be doing. How does the original concern I posted in my FIRST post about not wanting to spend $200 on a table saw blade, translate into spending $5000 on a CNC machine to you? I don't get it...
In any case. The trig I needed to figure out how much to shim my blank to cut ANY kerf I want with any blade, was already provided. So I can use a little bit of math, and create and add various shims to my stop to get a wider kerf of exactly the width I want. That's what I needed. I don't need recommendations to spend thousands of dollars to add machines to my already jam-packed full shop (that doesn't have an inch of spare room right now anyway) so I can do things "more easily." I'm a turner. All I've ever done is turn thus far. I'm trying to branch out into other things, WITHOUT spending thousands, or really even a dime, except on wood. I spent $500 on a low end table saw a bit over a year ago that I was originally using for construction. Now its a woodworking tool and I'd like to get some use out of it, before I spend more money on another machine. That was the goal. Being told by you that you had quite an extensive woodworking shop and business (which is actually where my quip about "wealthy" came from, not the CNC machine), and could do any of this easily, to be quite frank, is not helpful to me. Its bragging, childish, and quite frankly, a little annoying. I have no doubt that you are a vastly superior woodoworker than I am. I did not have that complicated of a question, which is why I'm surprised by the responses of a number of the forum members here, including you. For someone as superior in skill as yourself, you could use a change in tact.
Anyway, someone provided the real answer I was looking for already prior in the thread. That was quite helpful. Too me a sec to figure out I was accounting for my angles backwards, but now that I have, I can cut any kerf I want with any blade I want (well, so long as its thin enough, I guess, can't cut anything thinner than the blade kerf.) That's good enough for me. I can return this full kerf saw blade and save myself $60. Maybe I'll pull a profit this year, if I do, maybe next year I'll bring in enough that I could spend some money on another machine. Until then....I have wood, I'm just trying to figure out how to use what I have, spend as little as humanly possible, and see if it is even possible for me to try and make a business out of this or not.
I'll bow out of this thread now.
I can't speak for other forum member's responses.
A number of years ago my first description of ovals was likely from where I learned most of what I came to know about woodworking. That was from the Delta series of books, "Getting the Most Out of Your xxxx". Each book covered a specific tool, table saw, lathe, drill press, shaper, sander and other shop tools. The table saw book shows how to do turnings on the table saw which can be a real eye opener. The oval process could be done solely on a table saw without need for a lathe by using clever jigs. The books are readily available through Amazon and other used book sellers. In our current litigious society no manufacturer would dare publish the information in those books about using tools in unusual ways.
I thought your question involved a lot of issues. The process you're wanting to do can be complicated. Complicated by the accuracy needed in the blank dimensions, having a saw blade that makes repeatedly accurate straight cuts, an accurate jig holding the blank for cutting, stopping off the center of your blank so the end doesn't have to be exactly square, etc. Then not cutting all the way through adds more complications if you have to get into shims to establish kerf width. If the cuts are all the way through the blank (like most Youtube videos show) the glue jig has to allow for precise clamping alignment where poor glue alignment can be a very major problem.
Somewhere in this thread was a discussion about thinner blades and I recently came across a Diablo 7 1/4" blade at a salvage store for only $14.50.
The method that I use to make celtic cross blanks has been to cut them on my miter saw and also to cut the insert from a like sized blank of the contrasting wood. The picture below shows that I had to make a sub table such that the blade is able to cut all the way through the blank. The wood back fence not only keeps the insert from flying off, it also provides a handy spot to check the thickness. Notice the hammer/fine adjusting tool.
Thanks for the idea! I actually saw the same Diablo blade at the local home depot. I think it was the same price. I did not get it, though, as I didn't think it would work on my table saw with my sled. I don't think I'd have enough height on the blade and all, once the sled was in place (and having tried, I wouldn't want to try and make these cuts without a sled.)
How are you determining the thickness of the piece you are cutting off? I did think about that, how to do that on the miter saw... I didn't have any good ideas there. I have, however, been building a new table saw sled, one that is more capable than my relatively pitiful first attempt. I'm including a dual miter/t-track in it, so I'll be able to use my miter gauge in it to get angles exactly as I need them, as well as clamp pieces of wood, or makeshift fences to it, which should make it a heck of a lot more capable than my prior sled. Hoping that this will do the trick once its done...
The blade measures .060" (1/16th" = .0625 ") The actual cut comes out to a little more than that, so I set the stop block to about 1/16", make some trial cuts and check them in the saw kerf. The picture below shows the setup and the hammer is used to make extremely fine adjustments to the thickness, than when the thickness is correct add some extra clamping force.
As Don Wattenhofer showed, cutting all the way through solves a lot of problems. But, if you would rather not do that, you can get a very precise ⅛" kerf by using one of the outer blades of a quality stacked dado set.
I think cutting all the way through only works if you can cut exactly the right width kerf that matches the insert thickness. The problem with cutting all the way through, and I see this in many of the videos I've watched and in a lot of finished products with celtic knots or other loop/ring style designs, is that a non-matched kerf with a full-through cut, causes misalignment of prior inserts after adding the next insert. I guess some people don't mind that? It bugs the crap out of me! :P Cutting a kerf part way through that matches the thickness of the insert avoids any problems with that. I really like Chad, so I am not trying to call him out here, but I just know that his video here he cut all the way through, and the turned blank does show misalignment across subsequent cuts for the inserts:
View: https://youtu.be/Lu5p1TQnlkk?t=3214
Chad is really great though, he does a lot of useful videos. I just want to strive for better quality without those missmatched loops, and while I'm sure you could probably find a way to achieve it with through cuts, I think its easier when you just don't cut all the way through.
If the kerf was exactly 1/8" and the insert thickness 1/8", then cutting all the way through could work. With a 1/8" thick insert, and a 3/32" or thinner blade, cutting all the way through causes more problems than it solves I think. I've been cutting most of the way through with a single cut, offsetting the position of the blank and making a second cut to cut out the remaining 1/32" in the kerf, then gluing in my 1/8" thick inserts. Overall I think this works and solves the problems I was having, but there is some nuance to it. If you cut most of the way through, you leave some material in the blank. If that material is too thin, then blank can flex at that point. If both sides of the blank aren't clamped, this can then potentially lead to other issues. But, clamping everything tight and making sure nothing shifts while cutting seems to prevent any issues there. The other challenge is shifting the cut just right. My original attempts were to angle the blank, with the saw blade at 90 degrees in the table. Shifting an angled blank the right amount to widen the kerf to 1/8" is tricky.
I found a video from one of my favorite woodworkers a few days ago, where he used a much simpler jig and angling the blade itself to make the cuts. I spent $7.99 on his linked PDF and built the jig. I originally thought about angling the blade, but, the way I was thinking about things, I guess I thought I wouldn't be able to get all the angles I wanted. Well, in some respects, I guess I can't, but after reading through this PDF and watching the video I realized it probably wouldn't matter. (It may also be problematic with angles shallower than 45...say 32 degrees, I don't even think the table saw blade could reach far enough anyway.) Further, I was measuring my angles differently. In any case, I made the jig from this video and have been using this approach, and its a lot simpler overall:
View: https://www.youtube.com/watch?v=0FUS4LZV_-8
I'm not getting perfect kerfs. I've made a few mistakes the first few tries. I need to tweak the jig...I didn't quite build it correct at first, and as a result I'm having problems clamping the front part to the back part, which is itself leading to inconsistencies when I shift the blank around with the front part. So I'm still working on it, but overall, this jig has been much better than my previous attempts using a more standard table saw sled and angling the blank itself (which had some other key issues...FWIW, I'm a beginner with table saws, and the last couple weeks have been full of learning!!) I think I'm going to try and bolt the back wood support for the fence directly to my miter gauge, instead of trying to attach it to the fence already on the gauge (its an Incra and came with one of their t-tracks built into the gauge, but the t-track can be removed.) Once I have a sufficiently tall piece of wood attached to the back part of the fence, I think I'll be off to the races.
I believe you meant to say, "NOT cutting all the way through only works if you can cut exactly the right width kerf that matches the insert thickness."
When you cut all the way through, a kerf no longer exists ... you just have two separate pieces of wood. You're good to go as long as all of your inserts are the same thickness.
The problem is the same weather you cut all the way through or partial. The problem starts with the 2nd cut causing misalignment and the 3rd & 4th cut just multiply the problem. The analyst is difficult to wrap your brain around and just as difficult to explain, I learned by trying it and found that there was no way to make it work. The one explanation that I can think of is if you use an insert thicker then the saw kerf then the bank becomes longer and the 2nd, 3rd and 4th cuts will be short by the difference resulting in misalignment. The same problem will exists with an insert thinner then the saw kerf.
The problem is obviously known by other early respondents to this thread.
I must be looking at too many Celtic knot videos. When I go to Youtube I keep getting rolling pins with a knot in the middle which I don't find attractive or a pleasing embellishment at all. There are applications where the Celtic knot can add to a piece. not rolling pins IMO though.
I do mean cutting all the way through. Let me be more explicit.
If you have a 1/8" kerf blade, and are using 1/8" thickness inserts, you cut all the way through, insert the first, and rotate. Now you cut all the way through again, put in your additional insert, and since the thickness of the blade and the amount of material removed by it match the thickness of the insert, you can add another insert, and when you glue the pieces together (assuming the pieces do not SHIFT!! I'll get into this in a sec), then the material from the first insert will still align.
NOW, if you have a 3/32" blade, and are using 1/8" thickness inserts, you cut all the way through, insert the first, and rotate. Now you cut all the way through again, put in your additional insert, BUT since the thickness of the blade and the amount of material removed by it do NOT match the thickness of the insert, the material of your FIRST insert, after gluing in the second, NO LONGER MATCH. The blade was 3/32", you inserted 4/32", which pushed the two pieces farther apart than they should be, and now the two halves of the first insert no longer align (or, if you make them align, then your blank is no longer square.)
So if you have a blade with a kerf thickness matching the material, ok, sure, you can cut all the way through.
DESPITE that, you still have problems when cutting all the way through. You have to make sure all the parts remain aligned, for each and every cut+insert. That isn't easy, especially if the insert isn't perfectly sized and overhangs anywhere. Then its quite challenging to keep everything aligned.
HOWEVER, if you always make your kerf the same thickness as the insert (and really, slightly larger to allow for some glue thickness as well, otherwise you run into problems regardless), but DO NOT cut all the way through, then you never have issues aligning the two halves of the blank around the insert, and the insert doesn't have to be perfectly sized to match the blank, at the given angle. The remainign material you did not cut all the way through, holds the blank together, and as long as the insert slides neatly into the kerf without pinch or anything, then when you glue it in you maintain a totally square blank. Trim off the insert excess, make the next cut partially through (leaving about 1/8", less than that and I find the wood flexes there and you have other problems), and add the next insert, etc. etc. I have a 3/32" blade. My inserts are 1/8" (4/34"), so I am making two cuts per slot. I'm having to shift the blank by 1/32", well really more like 3/64", which I have had a little trouble doing, but I'm making some adjustments to my jig to support better, and that widens each slot to fit the insert. My first couple of attempts, I did not leave enough material in place, and the wood flexed in the joint between the two halves around the slot, and that caused problems. So I'm trying to leave 1/8" of thickness at least, which seems to prevent that flex.
Someone mentioned I could add some layers of paper to one side of the blade rest on my arbor, which would throw the blade off kilter a bit, allowing for a 1/8" kerf to be cut with my 3/32" blade in a single pass. I fiddled with that, and I think that would only actually work if I made sure the full length of the blade contacted the wood... In any case, I seemed to have some issues with that. In particular, it seemed like at the top of the blade, the cut remained about 3/32", maybe very slightly wider, but at the part of the blade near the table it did cut offset more. Because the top of the blade didn't quite cut right, I seem to have ended up with tapered slots. So right now, following the video I linked, I'm offsetting the blank. and making multiple passes to cut the right kerf. I need to find a sticky back ruler with maybe 64ths on it, or at least 32nds, so I can make finer and more accurate adjustments. I've been guessing with the 16ths I started with and I'm not getting consistent kerfs. I think once I get this jig fixed up so it slides better, and get a finer ruler on it, then I'll have an easier time using it.
Doug, what exactly is your purpose for posting here? I honestly don't get it. I seem to draw people like you out of the woodwork (pardon the pun), who just have to poo-poo all over the thread, brag, and generally belittle.
I'll be frank. I don't care for your opinion, I think its childish and haughty which is unbecoming of an adult man, and while you are free to post, I'll be ignoring them from now on. Please, grow up a little bit?
ALSO, for the record, I'm not only doing celtic knots. Those are pretty specific. Some of what I'm doing involves randomly, unaligned, and more chaotic inserts. Often of different colored woods. In some cases I even want to do a combination of segmenting and loops. I could care less if you don't like celtic knots. That's not the point of this thread. The point of this thread was to determine how to cut a kerf of a specific thickness to match an insert of a specific thinckness, do so consistently, to allow for a simpler and much more reliable experience inserting anything, for ANY reason. Celtic knot or anything else.
Its about woodworking technique.
I haven't read all if this. Too long for my old brain. I am working on a system to cut miters for celtic knots with the bandsaw and using wood that us thicker than the blade. I've got it working and will try to do either an article or a video in the next 3 or 4 days. EASTER weekend may mess up my timing.
I haven't read all if this. Too long for my old brain. I am working on a system to cut miters for celtic knots with the bandsaw and using wood that us thicker than the blade. I've got it working abdcwill try to do either an article or a video in the next 3 ir 4 days. EASTER weekend may mess up my timing.
I'd be interested. I have seen a few videos with guys using bandsaws to do celtic knots and other "chaotic loop" style things. So far, though, I think I've only seen single partial-through cuts, and thin materials like veneers, as the inserts. If you have a reliable way to cut a kerf of any width with a bandsaw, I'd be quite interested to hear it!
Yup, this is it exactly. I don't know if I explained it well enough in my previous post or not.
I'm getting more experience with this now. I am still a beginner with the table saw, and I seem to have some trouble with the second cuts I'm making, somehow not being perfect. What I am running into, is if I make a cut like this:
Code:
             v-------------- this part is narrower
      ^-------------this part is wider
The bottom is a bit wider, top narrower. Bottom fits the insert plenty, top its a little tighter. I don't quite understand it...thought it was just because of flex in the remaining material at the top. But that is now 1/8" thick, which seems to be plenty thick to avoid flex. I've tested my blade alignment, front to tail, and its as strait as can be. I also checked my riving knife, and its dead center. Now, I am using the blade at an angle, not 90 degrees strait up. I don't know if somehow that is causing problems. In any case, the bottom of my kerf seems to be slightly wider than the top, so its more like a wedge shape than a perfect kerf. When I clamp, that is causing some shift. So I still have things to work out here. I'm wondering if the blank is moving and causing the problem. I'm too afraid to hold the blank with my hands, and using clamps, seems to result in some shift one way or another. Unless my blade is wonkey some how at an angle, I think the way the blank is held must be the problem.
If your kerf is wider at the bottom than at the top it may be due to the blade being out of alignment to the miter slot. It is important to check the alignment with the blade both vertical and tilted. If you are not familiar with the procedure check out this video.
View: https://www.youtube.com/watch?v=tNfvtStKkFA
This is important whether you are doing through cuts are partial cuts. Another thing, I don’t think 1/8” is enough to prevent flexing (depending on the wood species). If the kerf is only slightly less than the insert thickness you may be wedging the cut open. As far as using clamps rather than fingers that should be better. Do you have sandpaper on the front of your fence? That really helps with preventing shifting.
The light bulb came on as soon as I read the issue with the second cut. Thanks.
I have a peppermill with a Celtic knot that a late friend made. He was always looking for something new to challenge him and was pushing 90 when he made this peppermill. I haven't been brave enough to try making a Celtic knot.
Speaking as a longtime cabinetmaker, the idea of making two cuts with an undersized blade to get consistent width kerfs makes my head hurt. A drunken sawblade (shimmed to make a wider kerf) can work, but it is a pain to set up precisely without a pair of tapered washers. I would simply use a 1/8" kerf blade and size the material to fit the resulting groove. In my shop I would run the filler material through my drum sander. In a town the size of Aurora I am sure one could easily find someone with a drum or widebelt sander to do the job. Lacking access to a thickness sander I would use a thickness planer with an auxiliary bed or rip the material on the tablesaw using featherboards for consistency.
Correct me if I am wrong but I believe widebelt sanders have a rubber platen that the belt rides against and a rubber conveyor belt which will tend to slightly round the edges of the stock being surfaced. I have one of the newer drum sanders with the aluminum drum and abrasive belt conveyor dubbed a 16/32 will not round the edges, but the drum does lift a bit that causes a bit of inconsistency. The bracket shown along with adjusting the conveyor too parrel the drum makes anything run through it about as accurate as possible to surface a piece of wood.IMG_1385.jpg
This is the jig I use on my Delta 14" bandsaw. The blade is the thinnest I could find - 5/8 x 3tpi. The knot inserts consist of 3 pieces of veneer glued together and the first cut is a shade too narrow to
accommodate them. I insert pieces of very thin card or bits of paper between the blank and the stop block and then cut again. For both cuts, the feed rate is very low so that I get a smooth cut.
Correct me if I am wrong but I believe widebelt sanders have a rubber platen that the belt rides against and a rubber conveyor belt which will tend to slightly round the edges of the stock being surfaced. I have one of the newer drum sanders with the aluminum drum and abrasive belt conveyor dubbed a 16/32 will not round the edges, but the drum does lift a bit that causes a bit of inconsistency. The bracket shown along with adjusting the conveyor too parrel the drum makes anything run through it about as accurate as possible to surface a piece of wood.View attachment 74667
Most wide belt sanders have some kind of platen for finish sanding and rolling the edges can be an issue depending on the machine and operator, but for dimensioning the platen is taken out of play. I haven't had any problems with deflection with my drum sander, but I like your modification.
Thanks Graham that gives me another option to play with. Without going into much detail. I use feeler gauges to shim the stick fir the second cut. I measure my veneer. My blade makes a .035 kerf. If I double that for 2 cuts that's. 070". I subtract that from my veneer thickness and that tells me how many gauge shims to use. In my case it came out to be .045" so I used a .020 and a .025 feeler gauge shim to move the wood.
You should give it a try. It takes a few tries, I think, to get all the little details sorted (such as my angled blade issue with wider kerf at the bottom), but once you do they are actually pretty strait forward. You make the first slot, glue in your insert. After the glue dries you make the second and glue in, and repeat for the third and fourth sides. It helps to label each side, so you know which side is which. You can also make the cuts just 1-2-3-4, or do 1-3-2-4. The latter changes the way the inserts overlap each other, and some people prefer that over the 1-2-3-4. If you make the jig in the video I linked, it makes making the cuts easier for sure. Just...make sure you build it right (I didn't quite the first time.)
This was my original idea, to do exactly as you have. Place the blank at the desired angle, make a cut, shim the blank, make another cut to widen the kerf. I was originally doing this on the table saw. I can't make cuts thin enough on that for the pen blanks, so I'll probably do this with my bandsaw instead. I think I have a 3/4" metal cutting blade in there now...IIRC its 8/10 TPI. I forget the kerf, but, its doubtful it would neatly fit any insert material without a second cut. I may have enough material left to make a similar sled/jig out of the remaining material after making a few other sleds. I even have a bit of T-track left...and I'm wondering if I might be able to put a couple of T-tracks in it so I can have an adjustable fence.
Oh, feeler gauges! I didn't think of those, but that is perfect.
