Bolt Size
Montfort, Wisconsin
What size bolt is used to hold the Oneway bowl steady to the clamp bracket? It appears to be 1/2 inch by 2 inches but I wanted to be sure. Thanks.
When you purchases a Oneway you get the whole company with it.
You'll be put on the phone with one of their engineers or with Kevin, president and owner.
While I would make that call, I will also bet that the bolt is metric. If it looks like a 1/2", it's probably a 12mm
