Charlie Harley said:
What gouge do most folks use for working bowls? How big are your typical bowls?
>>from 2" up to 12"
How big is it? And please define your sizes as either distance across the flute or diameter of the bar stock.
>>I use a 1/2" flute bowl gouge for roughing, a 3/8" flute for final cuts on the outside & inside walls. I use a 1/2" flute bowl gouge with "factory grind" for the bottom inside.
What grind do you use? How do you get that grind? Pictures would be helpful here.
All help is gladly accepted.
>>I don't have any pics, but the 1/2" bowl gouge for roughing is "Irish grind" style with swept back wings about 1" long, and a 40' bevel in the front. My definition of bevel angle is from the flute to the bevel (other's use from 90' to the flute to the bevel). Takes a lot of wood off very quickly with little effort. I just chuck up the bowl blank between centers, and come in from the tailstock side with the flute facing towards the headstock and the bevel pointing where I want to go. The thing one shouldn't do is present the cutting edge so you're digging into the grain (flute faceup and attacking the wood perpendicular to the lathe as if you're roughing spindle work).
Note that Mouse is not advocating that type of approach for bowl work - he presents the cutting edge of the continental style gouges in a similar manner as I present the cutting edge of the bowl gouge, though the angle of the tool to the axis of the lathe is obviously different, and the tool rest is in a different orientation as well. There's been discussions a plenty on this in this and a couple other forums, and I will leave it at that.
The 3/8" has swept back wings, don't know how long, but 40' bevel again. The 1/2" flute with factory grind has a bevel much steeper - maybe 60'? I use the Wolverine extra large platform to set the bevel angle, but the rest of the movement is all by hand to get the wings, etc. needed.
Lastly, these are all methods that I have observed in classes & demos, and I have selected those I have found work well for me. I'm not an original
