brass end on knockout bar
Melbourne, FL
hi y'all
just got a new-to-me lathe and i noticed a 300 savage casing taped the the end of the knockout bar ...
why ?
thx
Steel can bung up the end of MT when you knock it out. Of course to do that, you have to hit it really hard. I made a new knock out bar for my lathe and added a bit of brass (brazing rod) to the end for that reason.
ok absolutely reasonable so i need to braze then , because this makes it too big a diameter to fit through the tailstock ...
I made my own knockout rod from 3/8" brass stock cut to size with a simple turned handle. I also made skinnier knockout rod from 1/4" brass stock so that I can adjust the point on my Robust live center without removing the center from the tailstock.
Here's what I use home made 3/8" brass rod. Minimal cost and it looks cooler than the one that came with the lathe🤔🙄😁!
Cheers.
Barry W. Larson
Calgary, Alberta, Canada eh!
