Burl orientation advise
Merced, California
Greetings all,
I just liberated a rather large maple (unknown species) burl from a neighbors tree. To my surprise it is not your standard "pin style" maple burl. I think it would be called an "onion" burl. It is no where near as figured as I generally expect a maple burl to be but it does have nice layers.
Having never cut up an onion burl I'm a little hesitant to start chopping it up.
Any advise?
Done some birch and some maple blisters, and inside out - pith up - displays the multitude of angles best. Outside up shows shimmer best. I'd marinade a soft maple to brown it up. Can't with hard, but the contrast of changing grain directions looks more dramatic when the wood is darker.
If you're feeling adventurous, onion burls like that actually carve very nicely. It's an alternative to turning and will likely give you an irregular bowl but, by following the grain layer from pith out, you can get a very cool almost melted look to a carved bowl. Very organic vs. regular.
dk
MM, can you give a little information about this process? Thanks!
I just did a small maple burl bowl with natural edge. Athough I am very pleased with it, I think I would like to "brown up" the next one I do.
It's got to be cut with the sap up for best results, but then you age it near the bottom of the stack, where it develops a wine odor and the sapwood assumes the same color as the heart, only without the little cracks that happen there. Imagine it's fermentation waste that does the job, though not sure why. Looks lovely.
Here's a firewood chunk for example. Think there may be a couple of other pieces up in the gallery. Straight, and with BLO.
that looks to be quilted or tigre striped, i did not know that was a burl :confused:
That's right. Didn't have a picture of a burl at hand. Next time I'll try to do better. :)
