Chuck preferences
All very good info. The consensus seems to be that everyone has there favorite and they all work. As I figured it would be. Which is not a bad thing. The biggest choice seems to be the type of key it uses. I’m leaning towards the hex/allen key type just because they are not a specialty item and can be replaced at any hardware store if necessary. I have a bad habit of misplacing things and not finding them until I’ve bought a new one.
My goal is to go with one brand and stick with it to enhance interchangeability. We’ll see how that goes.
Thanks everyone for your insight.
what did you end up buying?
Some folks would omit the spindle roughing gouge and use their bowl gouge to rough our spindle blanks.
I usually omit the spindle roughing gouge and instead almost always take a square blank to round with the skew. I think it's easier and is faster to make a cleaner surface. It's important, of course, to not use a skew that's too narrow or risk a splintery mess! A 1" to 1-1/4" skew is great even for fat spindles, 1/2" fine for thinner spindles.
A rare but potential problem is with some particularly brittle wood and grain orientation - it's possible to start a split which can continue down the blank, getting deeper until it splits off a chunk (or even breaks the blank into two pieces!) Of course, this can happen with the spindle rouging gouge or bowl gouge as well! I do examine the blank ahead of time for problem grain.
However, two things can prevent an unwanted split. One is the usual method: start roughing very close to one end with each new pass a bit further away from that end. Start each pass by entering the wood with a cove-like curve then flatten that when heading towards that end of the blank. Then do the same thing in the other direction on the other end until meeting close to the middle.
Another little trick works to prevent splits on splintery wood - start by making a series of quick V grooves down the blank, cutting deep enough so the bottom of the Vs are close to the final diameter. If a split does start it can't get past the next V. As the corners are cut away, the Vs can be deepened a bit more, but that's usually not needed since with each pass there is increasingly more supporting wood.
If the square blank is long and thin, say 1/2" in diameter and maybe 12" or longer, the backside must be supported with the left hand just like a thin spindle. This might sound unreasonable and possibly painful but it's not - the support needed is very light and I always turn thin spindles a high speed. Securing the drive end in a chuck makes it easier still.
All this sounds like extra trouble but I think it is quicker and easier than using the spindle roughing gouge. Obvious if watching in person. I should make a short video.
The end result is the whole blank goes from square to a completely smooth cylinder with the skew. Note: I have beginners stick with slow cuts with the roughing gouge.
As for the roughing gouge, I mostly use the Thompson 5/8" with relatively thin spindles, not necessarily for cutting off corners but more for quick shaping of curves - especially good for shallow coves. Then refine those with the skew. Another plus for the Thompson is the "U" shape with a straight, vertical edge on both sides - in use the tool can be rotated during the cut to use those edges exactly like a skew. The 5/8" diameter is easy to hold so I don't mount it in a handle. That might be good to put in the video too.
After posting this I got a Oneway Talon. Seems good. After some more research I considered a Nova G3 but ended up ordering a Record Power SC4 which was delivered yesterday. Looks to have cross compatibility with a lot of other manufacturers jaws, including Nova, as well as those made for it so shouldn’t be short on options.
Whilst it does give you options for source of supply, I’m not sure it really gives you too many more options in jaws types?
The three main manufacturers seem to have copied each other for many of the types offered. One example.
Regarding jaw compatibility between various manufacturers - does anyone know if there are any that are interchangeable with the Oneway Stronghold? My lathe came with a Stronghold and several jaws and I love it. Just wondering if there are other possible jaw options beyond those sold by Oneway. I finally did order a second chuck body. Woodworker Specialties has Stronghold chucks 10% off now.
From their promo email: Use coupon code Stronghold10 at checkout for a 10% discount on your stronghold chuck! Valid until November 21st.
