Johnathan Silwones is starting a new AAW chapter, Southern Alleghenies Woodturners, in Johnstown, PA. (click here for details)
Congratulations to Peter Jacobson for "Red Winged Burl Bowl" being selected as Turning of the Week for April 29, 2024
I realize that I need to clean the MT on my lathe. Does anyone know where to get a reamer for it? I have tried the machine shops around me to no avail. Only thing I can find is 1 person on Ebay.
Packhard sells the urethane "Tapermate" which I use every time I use the headstock taper. I also pop the live center and clean the tailstock taper every so often. Don't forget to clean off the male side of the equations as well; dirt or grit on those will screw things up just as well.
A reamer would only be needed if there is scarring (as it is a cutting tool). The tapermate would do a fine job of cleaning the "gunk" out. Wood shavings, glue goo, etc.
