Decent Peppermill Kits?
Spartanburg, SC
As the title suggests, I'm wondering what some good peppermill kits are? I'm thinking about turning a few for Christmas presents. I got some of the popular pen kits last year, some of which turned out to be cheap junk that I wasted some nice wood on. I don't mind paying a bit more for a step up in quality. Thanks-Aaron
Beware some require forstner bits in the 1/16" increment. if you have the 1/16" forstner bits, no problem then. I like the chefware kits. Easy to assemble. Easy to adjust length. Different kits for salt vs. pepper.
I like the crush-grind from https://chefwarekits.com I made a tool to cut the grove instead of cutting off the tabs, seems easier then cutting and gluing however, both methods work. After giving away too many to count, I finally made one for myself... Made the bore oversized so I don't have to fill it every other day.
Ash, 10.5 x 2.5
Woodcut makes a cutter that cuts the different sized holes for the Crushgrind needed in one cut. Then all you need to do is cut a groove for the lugs (or cut them off and I think people use glue). A nice piece of equipment if you settle on the Crushgrind as the kit you like to make.
Don't even consider making a salt shaker, pepper mill, etc. until you get (and read) a copy of Turning Salt & Pepper Shakers And Mills by Chris West. There's a section in the book dedicated to the CrushGrind@ mechanism. Everything you need to know.
You don't need a "kit". Buy CrushGrind mechanisms (see Packard Woodworks at https://www.packardwoodworks.com/153201.html?Category_Code=). Pick your favorite wood (3"x3"x12") for the mill body and cap and turn the exterior to the shape that you desire.
Some photos of my work:
Suzie Salt Mill 1st Place September 2015 GCWA.jpg ______ Julie and Leslie Salt MIlls 1st Place July 2016 GCWA.jpg
Some info from an earlier post follows.
When properly installed, the CrushGrind@ mechanism requires no epoxy or similar adhesive. Here’s the deal.
Most, but not all, instructions for making CrushGrind@ mills provided by US suppliers specify 1) a 1⁹/₁₆” diameter hole in the mill body for the grinding mechanism, 2) removal of the spring clips from the grinding mechanism and 3) use of epoxy (or similar) to secure the grinding mechanism in the mill body. These same instructions specify 1) a 15/16” diameter hole in the mill cap for the stopper, 2) removal of the spring clips from the stopper and 3) use of epoxy (or similar) to secure the stopper in the mill cap. One can make a very nice pepper/salt/spice mill using these instructions. But there is a better way! It’s the no epoxy-required way.
The manufacturer’s recommendation for the diameter of the hole in the mill body for the CrushGrind@ mechanism is 38mm (1.496”). I am good with calling that 1½” (1.500”). The manufacturer’s recommendation for the diameter of the hole in the mill cap for the stopper is 22mm (0.866”). I am good with calling that 7/8” (0.875”).
No epoxy (or similar) is required to secure the grinding mechanism in the mill body and the stopper in the mill cap if 1) the CrushGrind@ manufacture’s recommendations for the mill body and mill cap hole diameters are used and 2) a groove is cut in the mill body and the mill cap to accept the spring clips on the grinding mechanism and stopper.
Sorby makes a groove cutting tool for CrushGrind@ mechanisms. It's available on Amazon at https://www.amazon.com/Robert-Sorby-895CGH-Crush-Grind/dp/B00JMJKML2. It’s a must-have tool if one is going to install the CrushGrind@ mechanism in pepper/salt/spice mills using the spring clips and no epoxy.
With the grinding mechanism and stopper press fit into the mill body and cap, respectively, and the spring clips lock into the mill body and cap grooves, epoxy is not required for a secure fit.
An excellent set of instructions for making a pepper/salt/spice mill using the CrushGrind@ mechanism can be found in Turning Salt & Pepper Shakers and Mills by Chris West, “Drilling and Fitting a CrushGrind@ Mechanism,” p 132.
In my opinion, the CrushGrind@ mechanism is far superior to the stainless steel grinding mechanisms. It can be used to grind pepper, salt and spices. The grind can be adjusted from coarse to very fine. It’s made of non-corrosive ceramic. There is a 25-year guarantee on the ceramic parts inside the CrushGrind@ mechanism.
Give it a try. I think you will like it. – John
PS - The Sorby groove cutting tool is notched to register the correct depth of the groove in the mill body. It is also etched for the correct depth of the groove in the mill cap. - J
The first exposure to the Crushgrind for me came from Brendan Stemp who has good videos of using the Crushgrind. On his site he had photos of the cutter he made for cutting the groove. I tried making a couple but found the Sorby groove cutting tool worked great and did not continue trying to make the other work. His site is where I also learned about the Mill Drill that cuts the holes. It has 2 adjustable cutters that make the drilling a snap. I did an article on it.
Since I am not familiar with either the Mill Drill or Sorby's tool can you tell me if both are required for efficiency? I assume it's quicker to drill the hole(s) first with the Mill Drill and then use the Sorby tool for the grooves. Is this accurate?
A couple of comments on the Crush Grind units. First, I use a 1.5 inch Forstner bit and then ream the hole as needed with a small side-cutting scraper. Second, there a tendency for the cap to fall off in use if it is not fitted well. Let the metal rod protrude as much as possible when fitting the cap.
Dennis - You should not have to ream the mill body for the CrushGrind mechanism when using 1.5" hole in mill body. CrushGrind mechanism can easily be pressed into the 1.5" hole until the locking lugs engage the groove in the mill body.
The mill cap will not fall off if the grinding shaft if properly fitted into the mill cap. See photo. - John
I noticed that Crown makes a CrushGrind tool as well as Sorby. Any thoughts on which style performs better?
Bill - The Sorby groove cutting tool is notched to register the correct depth of the groove in the mill body. It is also etched for the correct depth of the groove in the mill cap. Crown has neither the notch nor the etched line; therefore, I would recommend the Sorby tool. - John
The groove the the lugs fit into is about 3/16th wide by 1/8th deep so making a tool from a leftover scraper is easy and saves money to spend on the MillDrill.
I understand what Dennis is saying about the cap coming off. My first grinders used the 1 inch part of the cap insert to index the cap to the bore body, and yes, if grinding with wild abandon, the cap would come off. I have since added a larger diameter tenon (?) to the top, one, because I grind with wild abandon, Two, because I wanted a larger bore for more peppercorns, and three, it alleviated the problem of the cap coming off mid grind. Lots of trails to follow, lots of good information above. One thing I would mention, Fostner bits are sharpenable...
Mill w:tenon.jpg
Thanks John for your insights. Looks like I'm adding a new tool.
A possible advantage of cutting grooves
You could at a future point in time dismantle the peppermill ,turn a new mill and reuse the crushgrind mechanism
It also solves the question of what to give the wife each year on her birthday or for Christmas
I don't make many mills, so rather than invest in the mill drill or the sorby groove scraper I noodle by with a little glue and using the forsteners I have on hand...if I was to make more than a couple a year, I'd stand in line for both, but...
That said, the crushgrind mechanisms work best for me - both salt and pepper.
John, I wonder if the crushgind mill kits obtained from different sources are identical. I just ran an experiment using a kit from Craft Supplies. I drilled a deep end-grain hole into a scrap of hard wood using a 1.5" Forstner bit. The hole size checked dead accurate on my digital calipers. I found that I could force the end of the grinder body, including the locking lugs, into the 1.5 inch hole with a strong manual force and a bit of rocking of it. However, I could not by hand force the rest of the body into the hole. Conceivably, a rap with heavy mallet would have forced it in, but at the risk of splitting the wood body. Given that risk, I choose to spend a bit of time to ream the hole just a bit.
into a scrap piece of
Crushgrind do make 2 variants
I received this reply to an e mail I sent to CrushGrind Denmark
The mechanism supplied in the Uk is CrushGrind Diamond
The mechanism available from stock in Denmark and our local partners is called CrushGrind Diamond.
We also have a mechanism range called CrushGrind Quadro, but this is only available FOB China and in larger volumes.
But actually, the guarantee and dimensions are the same on Diamond and Quadro.
The Quadro is our latest and patented version. But as mentioned this is only available in larger volumes (MOQ 5,000pcs).
Aaron, I use the Crushgrind mechanism that can be purchased from Penn State Industries (pennstateind.com). It goes by the name 'PKGRINDTL' and sells for $9.95 or less (depending on quantity). The mechanism is well built with a ceramic grinder section and an aluminum shaft that can be cut to length for your specific peppermill design. Because the mechanism was made for metric sizing, the 1 1/2 inch hole you make at the bottom of the peppermill is just a little bit too small for the mechanism body. You correct this by trimming off the six ridges on the peppermill mechanism body. Then the entire mechanism can be pushed into the 1 1/2 inch hole for a fit check. Also, I do not use a groove for the tabs to engage because this would make it very difficult to remove the mechanism if you ever need to (believe me I have gotten some strange requests from customers who have twisted the aluminum shaft completely off!). Instead of the groove for the tabs I use three stainless steel screws in the bottom of the peppermill within the recessed opening to lock in the mechanism. You can see the PKGRINDTL mechanism, the trimming area for the ribs and the three screws in the attached images. Hope this helps.
I emailed CrushGrind in Denmark during 2020
Attached are copies of the files I received Additionally I have included diagram of a CrushGrind tool which may be useful
Brian and everyone else-I can't thank you and everyone else enough for all the helpful suggestions. Sounds like the crush-grind mechanism is the overwhelming preference. I hope to get to some of these soon, but for the past month-plus I have been trying to keep a very big English department of a huge suburban high school running, with numerous teachers and students out at any give time either with covid, awaiting test results, or just quarantining (not to mention some I think are just taking advantage). Plus I'm teaching our largest AP English Language and Literature class in decades along with a couple of sections of English IV Honors. Oh, and we got almost an entirely new administration, which was desperately needed, but we're basically re-inventing a large high school. Don't get me wrong-I love my job more than words can express. It's truly my mission in life, but it definitely limits my shop time until I get a break.
That said, your suggestions are appreciated, and will be acted on at some point.
edit: I try to keep a sense of humor about things. I kept saying that last year was my most challenging year in 25 years of teaching, but this year said, "Wait, hold my beer," lol. Turning is helping me stay sane. In fact I'm finishing up a beautiful black walnut bowl today. Take care of yourselves, gentlemen. Now back to the topic.
I agree. I use crush grind all the time. I have the mill drill but don’t like it. Takes forever to set right size to drill and leaves to many marks to clean up. A really sharp forstner bit works much better. A Aldo have the sorry groove cutter. Works really well and fast. Love it.
John perhaps I am being a little pedantic
The imperial forstner bit sizes recommended are constant but there is a
variation in the metric sizes from different sources
Please see the files In my post 18th September (8.53am)
The file from CrushGrind Demark indicates sizes of 42.5mm ,38mm,and 22mm
NB The diagrams do give tolerances
The CrushGrind tool file sizes 45mm 38mm and 22mm
Page 132 of Chris West's book Turning salt and pepper shakers and mills, states metric
sizes 44mm, 38mm, and 22mm and imperial sizes of 1 3/4, 1 1/2, and 7/8
The imperial sizes I commonly see stated in posts in the USA are
These equate to 45mm 38mm and 22mm
Hi all for anyone interested here is a Peppermill production demonstration that features the Woodcut Mill Drill presented by Colwin Way (see the Woodcut Mill Drill about 17 mins in)
View: https://www.youtube.com/watch?v=rLWWqXvKXZU&t=1060s&ab_channel=AxminsterTools
I have been turning for over 30 years now but have never made a pepper mill. Getting ready to turn my first one. I am really glad I found this thread as looking at You Tube the hole size recommendations vary a fair amount while some cut tabs and others don’t.
You may find some of the information the links below useful
A few additional key points
(1) Ensure you make the surfaces of the between the top and bottom concave to create close mating fit Take care with this step
(2) It is essential the length of the top is longer than the dimensions of the top mechanism You can always reduce the length Also if the top is over length you are more able to match the height of two mills I would strongly reccomend being generous with its length
(3) Take care when shaping the peppermill not to make to bottom edge of the peppermill too thin Shape the body and finish the end carefully last
(4) If you have a large cone centre you can use it in the base of the mill after drilling the holes to centre it on the lathe and enable you to shape the body
These are all learnig points I discovered the hard way
I have had kits for a while, and need to 'get a round 2 it' some time. I did watch Nick Cook turn one at the Oregon Woodturning Symposium earlier this year. The common sense side of me thinks it would be easier to drill them out on the drill press. I did ask Nick that, and he said not really. I may have to try it anyway. The drill press is made for drilling. Lining them up to be vertical should not pose any problems, and if I am doing them in batches, I can so a number of them on one position/set up. The big question for me is do I want the ones with the screw tops to secure the grinding mechanism, or the Crush/grind ones?
Jim, your reference to different hole size recommendations and cutting tabs vs. not suggests that you are asking about the Crushgrind mechanisms. (If not, ignore what follows!)
Though I still do some mill mechanisms with top nuts, I have mostly switched to Crushgrind mechanisms and I like them a lot. And yes, there are a lot of different hole size recommendations, a situation that is complicated by the varying use of metric and imperial dimensions and the use (or not) of the Woodcut mill drill that is specifically made for Crushgrind mechanisms. I downloaded every Crushgrind instruction (including the company's "official" dimension instructions) and watched every video I could find, and then tried a bunch of different approaches for the through hole, the base holes and to top hole, the sequence of everything (which can vary) and the different ways (centres, chucks, and several custom friction drives) for spinning the blank on the lathe.
I think that you will have to gather a bunch of instructional material and do the same trial-and-error thing, and try a few mills to figure out what works for you. I got a recess-cutting tool (Sorby and Crown make them) so I don't cut the tabs. I also eventually got the Woodcut mill drill for ease and speed, but if you can work your Forstner bits to the correct depths it is the same thing.
It sounds like a lot of "up front" work, but once you settle on your tools, work holding methods and order-of-operations, it is a quick process, especially if you work in batches. And I kind of like the small complexities of making mills, it gives my brain some practice. The resulting mill is great and I find that the infinite variability of the Crushgrind shaft length gives useful flexibility in design.
Gord
Sadly none of the mill mechanisms I've tried seem very good. They all suffer from being very slow if you need to grind a tablespoon or two of pepper for a recipe. Most are pretty bad at doing a nice uniform coarse grind and don't deal well with larger peppercorns. The Crushgrind (TM) mechanism I tried wore out within a year of use. None really compare with a good Peugeot mill.
I have had the same problem with any mechanism made with ceramic parts where the 2 sides of the grind mechanism do not have anything to prevent them from contacting each other and since they are the same hardness they wear each other out.
