- Joined
- May 16, 2004
- Messages
- 3
- Likes
- 0
A history search failed to yield any information on this problem.
Lathe is an older version of the 46-700 (on-off switch on motor), but with same variable speed pully. Neighbor purchased new model 2 years ago and has same problem: Machine gets very hot after running 30 minutes.
Local warrenty shop has serviced this problem twice; first didn't put head together, second attempt re-assembled, but variable speed left lose. I tightened tension to get some pully engagement, but still over-heats.
Inside of variable speed has before slipped on shaft and rubed against shoulder. I checked, but this is not the problem this time.
Assistance would be appreciated.
Charles
Charles
