Hello All -
I am finishing a small piece with Deft Rattlecan Laquer in semi-gloss. I am also using their branded sanding sealer as well.
My procedure so far has been to sand the piece to 220, apply 3 coats of sealer, and then sand with 320. On top of this I am adding a fine coat of laquer every 30 minutes as per can instructions to a total of 3 coats sealer, and 4 coats Laquer.
My question lies in the final finishing. Will 4 coats be sufficient to wet sand to say 1,000 grit without any problems, or should I go to 5 or 6 coats? I plan to go with 400 - 600 - 800 - 1,000 grits.
thanks
Andrew
thanks
Andrew
