General 260V-Electronic Variable Speed lathe For Sale
Status
Not open for further replies.
Delaware
General 260V heavy duty, electronic variable speed wood lathe with 20" riser kit. I'm the original owner and the lathe is in excellent physical and operating condition. Includes the following accessories: Outboard bracket with tool rest base, (allows up to 28" diameter outboard turnings), 3" & 6" diameter faceplates (both LH & RH threads), 12" & 4" tool rests, knockout bar, wrench, 4 prong drive & cup center, remote on/off switch, and a polished 5" handwheel. Has an electronics package which converts your household single phase 220-volt power to 3-phase current, which makes infinitely variable speed control possible. Uses built in phase converter. Lathe is located in Windsor, CT. Local pickup only. Price reduced: $2,000 or best offer. pbfocus62@gmail.com
Specs:
- 20" swing over the ways, 28" swing outboard
- distance between centers: 38"
- bed length: 58"
- center of spindle to floor: 41"
- #2MT on head and tail stock
- inboard drive spindle threads: 1 1/4"- 8 RH
- outboard drive spindle threads: 1 1/8"- 8 LH
- weight: approx 650 lbs
- drive spindle: 1 1/2" diameter
- full power turning from 3000 rpm down to 5 rpm
- motor: 1hp, 1800 rpm 3-phase motor, w/4-sheave pulley
Status
