What is your favorite bowl gouge or tool used and how long is the handle? Also do you fashion your own handles?
The three or four turners I have worked with longest would all give you a different answer. I have taught a couple classes a year for 6 years with one of them. We let students use our tools. Our preferred bowl gouges differ in manufacturer, shaft diameter, flute profile, handle type and length. And the grind we each use.Seems like a simple enough question to me.
Depends on what I'm turning - large bowl, small bowl, shallow, deep, etc. I'm not sold on U shaped gouges. Size goes from 3/4" to 1/4". Handle length on most is around 14" - 18". Some tools came handled and some I had to make handles for. Seems like a simple question but when you begin to think about it ... too many variables.What is your favorite bowl gouge or tool used and how long is the handle? Also do you fashion your own handles?
I use the Ellsworth grind mostly (have a small gouge with Michelson grind and a 1/2” thompson v (5/8 D) with a 40 degree)What is your favorite bowl gouge or tool used and how long is the handle? Also do you fashion your own handles?
Some good advice. Choice of tools (and grinds and handles) comes down to what *you* want to make and your approach. Do get some guidance on the basics of sharpening -- you will have to find what works for what you do.Glenn.....until you get some stick time at the lathe, just get a standard plain Jane M2 gouge from one of the major sellers. Practice with different grinds and when the time comes, YOU will know what you like.
Don't let someone else be your guide.....you be your own guide to where you go with lathe turning.
There are no silver bullets, or magic.......time in the saddle is the only thing that matters.
Yes, I sometimes fashion my own handles, but any of the supplied wooden handles are very usable. Personally, I don't like the very long handles, and sometimes cut some off the end......but, this is my personal preference, and not necessarily a suggestion.
I understand there are as many varieties of gouges as there are stars in the night sky from individual to individual. Thank you that was a direct answer to my questionMy favorite bowl gouge is a Doug Thompson's deep V 5/8 bowl gouge. I have a few with a 40/40 grind and a few with the "Thompson Grind" I make my own handles but I also like Doug's handles, the longer the better, and I have several Stuart Batty handles, my longest is a 42 inches long.
Odie, I appreciate your comments. I am a multi media artist, have been all my life, I have worked with wood in all manner of building, construction, art you name it. I'm always pushing the boundaries if there are any. I do have time at the lathe with a number of different sticks as you call them, years ago and a rekindled desire now at age, with time, to turn bowls. One thing I discovered very shortly after receiving this Grizzly lathe it is nothing like what they advertise, falls woefully short and I am replacing it. I was just looking for general input from others on length of chisels they use. Thanks. The more I learn on a topic only reinforces how little I know .Glenn.....until you get some stick time at the lathe, just get a standard plain Jane M2 gouge from one of the major sellers. Practice with different grinds and when the time comes, YOU will know what you like. More than anything else, trust your own senses. Don't forget to try the very old and neglected traditional grind, as well as all the more modern swept back grinds.
If you need a suggestion......I'd go with Sorby.
Some turners become professional students.....because there is just too much saturation of information out there. This is why it's important to take the initiative, get some basic information, and run with it......time in the saddle......no substitute for it.
Thanks for your input. I have some experience and curious what others use.For scrapers, my go to is a Big Ugly tool, and yes there is a video I did about it. Also check out 'Scary Scrapers'. For gouges, I prefer the Thompson or D Way 5/8 inch gouges. I think most of my handles are in the 14 to 16 inch lengths, and I make my own. I prefer a straight cylinder, it just feels better in my hands, and I have at least one video on that. I do not like the weighted handles. Just too much weight to push around if I am doing a long day of turning, which I still do from time to time. I don't use a swept back gouge at all any more since switching to the 40/40 grind and a BOB (bottom of bowl) gouge for the insides of my bowls. Stuart Batty uses really long handles, way too long for the way I turn. He turns bowls on a long bed lathe, I use the sliding headstock, and now have one lathe that pivots. With the long bed lathes, you have to hold your arms out farther away from your body or bend over, which is not good for the back. Short bed lathe, and you stand up straight, keep your arms in close to your body, and I keep the tool handle under my forearm. I haven't had a parabolic fluted gouge in quite a long while. I should add at least one to my arsenal, just out of curiosity....
thanksI use the Ellsworth grind mostly (have a small gouge with Michelson grind and a 1/2” thompson v (5/8 D) with a 40 degree)
My preferred bowl gouge is the 1/2” jaimison gouge (5/8 diameter bar) made by Thompson.
I make wooden handles 18-20” long. Diameter that feels comfortable.
The length - I rest the end of the handle against the top front of my thigh when roughing about over the pocket or just below.
Your height, lathe height might be different from mine.
Your turning style could be different too.
Bowls Cove Ruffing cut -
View: https://www.youtube.com/watch?v=EIHADKjfL2c
Perhaps you meant the inverse. Starting with a 1/2 log or blank, 90% of the cutting work will be done with a big, long tool. That last 10% is the detail work.Bigger/longer gouges are useful for about 10% of the work overall. Good to have, but the real effort is in the finishing cuts that follow.
I suspect Odie takes a lot of time to prepare for and plan his detail cuts, but I dont think the detail tool cutting wood time is 90%. But, if he takes slow, thin finish cuts, then puts in the details, it could be more than 10%. Not exact %’s just educated swags.
I've not seen your work in person but from what I've gleaned from photos, the time taken by you finishing is evident in the quality of your turnings.Hi Doug......
The only way to know for sure, is to walk a mile in my shoes!
I suspect 99% of other turners rely on power sanding, and will always rely on power sanding. Because of that, they will never find out exactly what I'm talking about. Yes, as I said, I do spend that much time working on the final carefully executed tool steps for prepping a final tooled surface.....a surface needing a bare minimum of fine hand sanding. For me, time consuming, or not....it's worth every bit of the extra effort to accomplish it. Without it, getting the fine turned details is just not possible.
The closest turning group would be over $100 away with todays fuel prices.Glenn, it sounds like you need to find a local turning group and get connected with some folks who can show you what they've got.
Very nice what are the silver tool holders?For Bowl gouges I have Carter & Son, D-way and Thompson, 3/8” through 5/8”. It would be hard to give either of these the edge. Spindle gouges I have Crown and Carter & Son. Scrapers are Thompson. I make my own handles. I make an aluminum insert and I fill the handles with lead shot. Sizes range from 12” to 18” depending on the tool size. I do have a few Thompson handles.
Two of these handles I made square like the Thompson handles. All were filled with lead shot. I sand to 180 and I do not put any finish on the wood.
I’m a member of the Woodturners of North Texas club which is about 72 miles from your location. We have several club members who drive further than that.The closest turning group would be over $100 away with todays fuel prices.
putting me down for not driving distance to meet then I likely wouldn't want to associate with them to begin with
You have a talent for presenting your thoughts in an obnoxious way.I didn’t see a put down. Just a comment that many find the benefit of the meetings worth the drive.
t’s all choices you seem to know a lot about cattle. Did you just get a bull and cow and book or did you learn about cattle from mentors?
It has been my observation that folks who take classes and attend demos progress to a high level in a short time.
Those who are self taught usually have an inexperienced teacher and struggle for decades to get to where a one week course would take them.
What you might consider is checking out the demonstrators for upcoming meetings. You might find one worth the drive.
Truckpooling May be an option.
It wasn’t my intention to offend you.You have a talent for presenting your thoughts in an obnoxious way.
I have been officially turning for almost one (1) year. However, I have worked in wood for the last fifty (50) years. It is my personal experience that those routinely participating in this forum make an obvious effort to be honest without insulting. They offer opinions without being critical or condescending. I find nothing in those words coming even close to obnoxious. Again from my personal experiences those words were factually and fairly presented.You have a talent for presenting your thoughts in an obnoxious way.
I have been turning for over 40 years although I've taken a long break from it. Folks with your talent generally don't intend offense but they care not if they do, they just fail to consider how they present ideas and thoughts and how their discourse may be received. It is a special talent reserved for the elite.It wasn’t my intention to offend you.
