Green box elder bowl blank question.
I've got a nice 12" x 4" piece of waxed and green box elder just chomping at the bit to get on the lathe.
I'd like to turn it start to finish. Is this a pipe dream or should I rough it down to 5/8" or so and set aside to dry?
This will be my first box elder turning. I've turned a few bowls in green walnut and some dry maple...
Any advice is appreciated.
Tony Latham:cool:
bowl
hi tony,
if you decide too rough turn your bowl you will want to leave the walls 10% of the diamiter.12 inch = 1.25inchs if you want too turn start to finish i would say .25inchs all the way through the blankshould be fine.
Start to finish means you'll have a warped bowl. If you want near round, you'll have to TDT (Turn Dry Turn). While 5/8 would probably be enough thickness on a straight-grained shallow slope piece, you might want to leave a bit over, though not as much as an inch and a quarter, if the grain is irregular. Watch your shape, too. Broad bottoms and steep sides are more likely to split on you, as are thick walls. I find anything between 3/4 and an inch is a pretty good pick for a 12" or larger bowl. Gives me some insurance against rogue grain and a bit of restyle room if I change my mind.
If you want to let it warp, take it to 3/8 or less.
