Gun Drill Source?
In my comments regarding gun drills, I don't mean to imply they don't work. Just that hand guiding the gun drill may not create a straight hole so in deep drilling the entry hole and exit hole may not be along the lathe's main axis.
My experience is the same. Hand drilling with a gun drill works to a point. The deeper you go the less accurate it gets. My first try has been to replace the tailstock with a hunk of metal that has a guide tube through it. Drilling by hand is much more accurate with the guide but the length of the guide reduces the depth the bit can go. The piece is held by the chuck and a steady rest.
I have thoughts in my head about modifying a captured hollowing system to hold gun drills. Someday I'll find the time to try it.
For my hollow forms (and boxes and similar stuff) I usually prefer a filling a depth hole with a hand-held drill. For me it's just faster and more convenient than setting up the tailstock etc.
Usually, I use a gun drill for things more than a few inches deep. I find it drills straighter (twist drill will sometimes drift on me at the bottom of a deeper hole). Also, all the long twist bits I have (aircraft or electricians bits) only have short flutes, and have to be extracted often to clear the chips.
Anyway, for either type of drill, I make a starter hole using my spindle gouge. I use a 3/8" spindle gouge - same size as the bits. So the hole it makes acts as a guide to get the bit started on-center.
The gouge works essentially like a spoon bit, and creates a centered hole. I usually drill about 1" deep.
Two methods (hopefully my explanations are somewhat understandable):
- Start with the gouge bevel perpendicular to the lathe (cutting across the end of the blank) and curve in at the very center (fairly tight curve right at the center). Must follow the bevel all the way around the corner (or ride/glide/rub/float/etc the bevel however you think of it). Once at the center and the gouge is parallel with the lathe, plunge in.
- Start with the gouge parallel to the lathe, tip of the gouge right on center and just plunge in from there.
Both of the above require the tool rest to be exactly right to support the gouge - especially can't be too low or the gouge will chatter when it gets to the center.
The tool freak in me wants a gun drill now that I have seen Trent Bosch use one. Bosch and his daughter Kailee, did demos all day yesterday at the Robust factory in Wisconsin. Bosch only mentioned Ebay as a source, but there must be other sources.
Any ideas?
I bought one from Ebay some years ago before I saw that Trent was selling them. A bit shy of 3/8"in diameter and 11" long. It was pretty reasonable. I made a handle and added a valve and air chuck. It works like a champ for drilling long, straight holes.
