How I used scraps for end grain vessel.
Norristown, pa
This is how I used up some scrap wood to make a vessel. The pictures attempt to show the steps. All rings contain 12 wedges.
Picture 1 is the finished vessel with end grain showing. The wedges are cut with the end grain against the fence of the sled. A face grain vessel could be made if the rings are cut with the face grain against the fence instead of the end grain.
Picture 2 is the glue up strips from scraps. Two glue up were used, one is cut at 90 degrees (cross grain) the other at 45 degrees.
Picture 3 is a closeup of the top ring that was made from the strips cut at 45.
Picture 4 is a closeup showing the end grain.
Curious. If you used end grain red oak, would it leak?
Pat
