Hunter Carbide Tools!
Portland, OR
To my fellow turning genius’s. Today was the day. I was able to return to my lathe. Today was the first time I used a carbide tool. I used the Viceroy that Mike Hunter sold to me. My world changed. What a total joy turning a bowl offboard with my lathe set up the way we designed it. I turn in a wheelchair. I was in my powerchair in a crosswalk and I got run over by a drunk driver. She was 15 years old and went over me at 45MPH. Crunch. I got hurt bad. I have been busy working on getting my shop rebuilt at lap level. Last night I decided I was fit enough to turn. I had a blank of Birch mounted up ready to go. It dried while mounted on my machine. Hunter tools are golden. So to end… I have the small Viceroy. For the inside of a bowl what is my next carbide tool? Now for spindle work and the outside of a vessel what tool would that be? Yes I have asked before. I lost a lot of memory….
Thanks Much,
Thom Schuck
Portland, Oregon
Thanks Much,
Thom Schuck
Portland, Oregon
glad your back at it. I would suggest your next tool is a Hunter Badger. It's great for use as a bottoming gouge. It leaves a super clean cut. I use it a lot to finish the bottom on my lidded boxes as well. Here is my video on it. It was called a #4 when I got this one but calls them the Badger now.
View: https://youtu.be/nfp2kvhH6Mo?si=eBsPK3HD8Wt3Mhs6
Mr. John Lucas, Thank you so much for posting up your video. You answered so many of my questions with that one short clip. I know your name. Thanks for taking the time to help me out. Carbide is a whole new world for me. I am still not real strong so using my Hunter tool was pure joy. Mike Hunter extended an invitation to give him a call. I will do that on Thursday. I have made my way thru life as a professional woodworker. I owned a fine art custom frame shop for 25 years. I was exceptionally good at 45* cuts and could build square to unbelievable tolerances. Now I am making things round. Way more fun and rewarding. Doing things sitting down is really a challenge. My pals and X employees really rallied in helping me build a shop from the ground up. It is working out so well. I am grateful that you and others taking the time teaching me how things are done. It’s now fun. I got pretty good turning between centers. Then I got this wild idea to start making bowls. Now that I have discovered Hunter Carbide….I am cooking with gas! Thanks for the help. Best to you. TS, Portland, OR
I was able to return to my lathe. Today was the first time I used a carbide tool. I used the Viceroy that Mike Hunter sold to me. My world changed. What a total joy turning a bowl offboard with my lathe set up the way we designed it. I turn in a wheelchair. I was in my powerchair in a crosswalk and I got run over by a drunk driver.... Last night I decided I was fit enough to turn. I had a blank of Birch mounted up ready to go. It dried while mounted on my machine. Hunter tools are golden. So to end… I have the small Viceroy. For the inside of a bowl what is my next carbide tool? Now for spindle work and the outside of a vessel what tool would that be?
Hello Thom!
Oh my, what a life changer. You're story is inspiring. I had a good friend who relied on a power chair for most of his life, following of an event involving drinking and driving and a broken neck when he was a teenager. He never did any turning, but you would be amazed at his artwork - pencil, watercolor, huge paintings, couldn't reach the top so he painted that half upside down. (He had only limited use of his hands and arms) We both did technical and architectural 3D computer modeling and animation.
I'd be interested in the type and setup of your lathe. Twice I've met people looking for ways to turn seated. Do you have any pictures? Custom lathe?
Isn't the Viceroy great! I use it, plus other Mike Hunter's tools.
My favorite for all-around face work is the small Hercules. I use them both inside and outside of bowls and platters, turning and sometimes sheer scraping inside.
For example, I turn almost everything on my design of these pieces with the Hercules (everything except inside the base). I usually follow the Hunter with a negative rake scraper, then hand scrapers and hand sanding.
Perhaps of interest about this design. After making a few, Mike asked me once if I minded if he did some demos on these in his part of the country. It was way too far from areas where I might demo so I said sure. I never asked him how many demos he did, but I did get emails from several people who saw his demos and wanted additional details.
I also use them on the outsides of vessels, boxes, and more.
Even pieces like these, Beads of Courage boxes - roughly turned in sections from dry wood then glued together before final turning, I do most of the these with the Hercules and another Hunter tool (can't remember the name right now).
Mike has some curved and swan necked tools for inside tighter things - I even got one from him made just for turning insides with the lathe in reverse - handy at times. I also have a set of his mini hollowing tools, good for boxes, ornaments and such and larger hollowing tools. Don't get me wrong, I reach for a good bowl gouge or more traditional hollowing tools when appropriate but love the Hunters! :)
The cutters are razor sharp, of course. One thing you probably know, but if not, be careful: if you so much as lightly bump the an edge against another steel tool it will chip! I put protectors over the cutters when I put the Hunter tools into my "unhandled" tool drawer. I always keep a few spares of each size of cutter but Mike is very quick to send out some in a pinch.
As for spindle turning, I use the Hunters sometime, for coves and such, but far prefer a skew chisel and a 3/8" spindle gouge for smaller (finials, etc) and thin spindles such as conductor's batons and "magic" wands. To bad we don't live closer or I'd drop in and show you where I use what and why!
BTW, I buy all the Hunter, Thompson, and some other tools without handles and mount them in handles with aluminum or brass inserts I make. These are not hard to make on the wood lathe with woodturning tools - if you are interested I posted a document showing how I make these inserts:
BTW2, I can vouch for Sir Lucas: he's a certified trusted expert with the Hunter tools (and nearly any type of tool and turning!)
the Hunter Tools I have are: #1 Vive Roy, #1 Osprey, #1 Cygnet mini-hollower, #3 Hercules (that I won in a club raffle).
When I got the Cygnet I also got an aluminum handle adapter and the Robust collet handle.
And I can call Mike up and ask him to bring me something to the next club meeting.
We have a few people in our club that are handicapable. One in a wheel chair and that has to sit on a stool to turn which make my leg problems seem like nothing (I have neuropathy in both feet so neither have any feeling).
